Aeroovee to Rotax mount conversion???
Posted: Wed Aug 10, 2022 10:27 pm
by xeriotti
Hi everyone, I have an almost complete Waiex, just needs an engine to be mounted, instrument panel assembly and finish interior.
My plane has the aerovee engine mount from the factory kit but i recently purchased a Rotax 912ULS 100hp engine and i think it will be a better choice for my missions. And a better choice commercially (I live in Argentina, Its Rotax or nothing over here)
I will attempt to fabricate an adapter to couple the Aerovee mount to the Rotax 912. I know it can be done… It would be really helpful for me to see photos, hear comments and ideas, or any information that you guys may consider important.
Thanks a lot, i will post pics of my conversion as soon as i start working on it.. But im still on the research phase ![]()
Re: Aeroovee to Rotax mount conversion???
Posted: Thu Aug 11, 2022 7:29 am
Nice looking plane. Here’s what appears to be the easy way…convert the mount you have with this kit from Sonex:
https://www.sonexaircraft.com/eshop/car … ory_id=452
They also sell completely new engine mounts for the Rotax if you want a more elegant solution.
Good luck, looks like you’ll be flying soon!!!
Best, Gordon
Posted: Thu Aug 11, 2022 11:29 am
by 13brv3
The adapter concept is certainly appealing, but I’m sure no one would consider it ideal. This thread shows one adapter, but I never saw any followup about how it worked, or if it was ever even flown. In the final version, it didn’t looks too bad though.
http://www.sonexbuilders.net/viewtopic.php?f=60&t=579
I was in the same situation with a Onex that already had a mount attached. My first thought was an adapter, but I ended up scratch building a new mount using the Rotax ring mount rather than the bed mount. Of course in my case, the engine mount has no landing gear, so it made the mount MUCH simpler.
Getting one from Sonex won’t be cheap, but it will likely be the easiest solution. They’ve had some teething pains with those mounts, but now that they actually have their own Rotax installation, I’d expect any remaining issue to be sorted out fairly quickly.
One other option might be something in-between. Modify the existing mount by cutting off the tubes that go to the Aerovee, and replacing them with tubes that go to the Rotax ring mount locations.
In my opinion, you absolutely made a great decision to use the 912ULS. I wish mine was a 100 HP rather than 80, but I had the engine already, and it’s actually doing quite well.
Cheers,
Rusty
Posted: Fri Aug 12, 2022 6:15 am
My yet to fly Sonex Legacy (hope to get her of the ground within the month) is fitted with a Rotax 912 ULS and mounted using the Sonex : Rotax adapter.
The adapter looks great but was I disappointed in the fit.
Considerable “mucking about” was required, using home turned interference fit plugs, that were then drilled to suit the factory supplied engine frame - where is the QA?
Posted: Fri Aug 12, 2022 11:09 pm
by xeriotti
Thanks guys for the information… I already read everything about Sonex+Rotax easily available… Buying something from abroad is completely out of the table… I live in Argentina. We are having a hard time with politics and economy sucks (The last 70 years XD) So if its going to fly…Ill have to do it with my own hands
My engine arrives next week. If theres any way to make an aerovee/homemade ringmount coupling possible ill go that way… The bed mount is also tempting, but I think the ring is stronger.
The other option could be leaving the landing gear part of the mount on… cutting the non-landing-gear part…and starting from there. Ive done similar stuff before. Im a bit anxious, want to find the solucion and fly that baby asap!!!
Posted: Sat Aug 13, 2022 3:56 am
I don’t think it would be very hard to fabricate your own copy of the Sonex : Rotax bed mount - its not much more than 4 pieces of angle aluminium. Finding the right gauge/thickness might be a problem.
Posted: Sat Aug 13, 2022 11:59 am
by Kai
The exercise of combining the Rotax 912 ULS to an already existing Sonex mount, has been successfully carried out several times. This one is manufactured by someone really in the know Down Under, and combines the 912 without the Rotax ring mount to an Aerovee engine truss. Alas, no drawings available, it was a trial and error project.
Posted: Sat Aug 13, 2022 12:01 pm
by Kai
The installed engine in the airframe described above looked like this during a stage in the project.
Bearing in mind that the Rotax prop torque is massive compared to that of a VW-1 aeroderivative, I would be hesitatant to use this truss as such without some reinforcenent between the upper longeron attachment brackets in the fuselage, as indicated in the construction drawings for the Sonex A + Jab33A truss: a continuous square steel stiffener tube.
Posted: Sat Aug 13, 2022 12:14 pm
by Kai
A different solution was selected for a Rotax 912 ULS with the standard Rotax ringmount installed, mating it up to a Sonex engine truss for the Jab 33A. Incidentally, the installed weight of the 912 is fairly close to that of the 33A. Hence final CG location should not be too far off.
On a side note, the Sonex mount for the 33A positions the stop flange for the isolators apprx 455,3 mm forward of the front fuselage bottom/firewall intersection (Sonex reference point). The Aerovee mount moves this plane 58,8 mm forward. The mount for the light Jab 22A moves it a total of 135 mm forward. Hence I speculate that using the 22A mount for this exercise could pose CG issues (with the R912 hanging out there, far up front), while the Aerovee mount would probably work, provided very careful design of the ring mount.
Anyhow, for this excercise 12mm thick steel (it could very well be aluminium provided you can find someone that actually manufactures 12mm 6061T6 or 7075T6) adapter plates were manufactured, which also provided for the use of the harder Sonex rubber isolators for the Jab.
Posted: Sun Aug 14, 2022 7:52 pm
by xeriotti
I think i preffer mounting the engine from behind rather than the bed mount (i confess the bed may be easier and im still not putting out ofthe table)
Picking up my engine next week
I will keep you guys posted on that trip.
A set of 2" rubber isolators is on its way (Jeep Cabin isolators XD… I used them in other conversions, work great and costs 40X less than Rotax rubber mounts) . I will lathe turn the housings to mount them, that way i dont have to tighten them too much. they remain soft and absorb vibration efficiently and are also stronger and less prone to ovalizing because they are radially contained.
And it will be rigged something like this… (sorry bout that paint XD…will make a 3D when i have the actual measures if you guys are insterested)
Posted: Wed Aug 17, 2022 1:34 pm
by xeriotti
Jeep Cabin dampers arrived ![]()
They aborb vibrations between the cabin and the chasis of this Argentinan made marbles… IKA Jeep , IKA Gladiator, Ika Baquueano, IKA estanciera… No too often, but you can still see people drive this things on the streets over here…
Posted: Thu Aug 18, 2022 3:21 am
by xeriotti
Now its lathe timeeeee ![]()
Posted: Thu Aug 18, 2022 9:02 am
by 13brv3
It will be interesting to see how those work out. I used Lycoming size Conical mounts for mine, and it’s a bit stiff. It would have been nice to use the ones Rotax sells for the ring, but their insanely expensive like most Rotax parts.
Rusty
Posted: Thu Aug 18, 2022 2:19 pm
by xeriotti
I have 4 of these…un-contained (i mean they seat pretty loose over flat washers)…on top a Rotax 503 with bed mount… And… Its stiff, but propper movement is allowed. I suppose that this same rubber components with the container and under some preload will do OK for the 912. Trial and error. 40X cheaper than a set of Rotax rubber mounts. (and i can find them in almost any car spare shop in Argentina)
I bought this set online… PRICE? 9 US Dollars…including shipping XD
Posted: Sun Aug 21, 2022 12:30 am
by xeriotti
Well… Today was a happy day! My dad wants to see that waiex airborne so bad!! he came with me to pick up the 912… We vesited some friends along the way…
It might sound dumb, but im really happy to have this chunk of metal here… It took a lot of effort, but its here!
Already turn the rubbermount supports… I have some work to do in other aircraft, before i start to work full time on my Waiex, it will be post and picture heavy if you guys dont bother ![]()
Posted: Thu Aug 25, 2022 5:00 am
by xeriotti
Moved the waiex from my warehouse to my workshop… Almost have to take down the tail XD
Leveled it out to start measuring here and there
Rigged a high tech engine temporary mount to figure things out
Posted: Fri Aug 26, 2022 6:22 am
by xeriotti
I have my “kindaringmount” figured out… Made it out of cardboard, then cleaned those traces to make it aestethically harmonic… And transcribed it to DXF format so i can lasercutit…
Ive seen someone making an adapter from a solid piece os 12mm steel… But i dont know…i calculated it to be around 3 kilograms for the plate only… Ill try to make something lighter without compromising strenght… (sounds easy XD)
Posted: Fri Aug 26, 2022 9:37 am
by 13brv3
Looks pretty interesting so far. I wonder if you could that from multiple layers. Maybe something like 1/8" steel on the front and back, with 1/2" aluminum sandwiched in the middle.
Posted: Fri Aug 26, 2022 2:45 pm
by xeriotti
13brv3 wrote:Looks pretty interesting so far. I wonder if you could that from multiple layers. Maybe something like 1/8" steel on the front and back, with 1/2" aluminum sandwiched in the middle.
I already have a steel lasercuted version to see if everything fits…
My idea es to use 2 plates “flat” and welding them together on the perimeter to form a “box” In this image the rubbermount housings arent displaye but they would also take part on that structure, everything tigwelded together.
Material and thickness of the plates to be calculated yet… But it looks really good and its easier for my with my tools than bending and notching steel tube…
Anyone knows how thick is a Rotax Ring Mount? or have data on the weight? Rotax 912 is light so i have no worries about adding a bit of extra weight on this, but i dont like railroad track like parts on airplanes XD
Posted: Fri Aug 26, 2022 6:21 pm
by 13brv3
I don’t have any notes about the dimensions or weight of the ring mount. I can measure the diameter Monday if you still need it by then. I remember that it seemed heavy, but I couldn’t make an accurate guess of the weight. The installation manual for the Rotax does have some useful dimensions for the attachment points.
Rusty
Posted: Fri Aug 26, 2022 7:43 pm
by xeriotti
13brv3 wrote:I don’t have any notes about the dimensions or weight of the ring mount. I can measure the diameter Monday if you still need it by then. I remember that it seemed heavy, but I couldn’t make an accurate guess of the weight. The installation manual for the Rotax does have some useful dimensions for the attachment points.
Rusty
Knowing the weight would be important… To make an estimation of the thickness…its obviously 4130 steel. So depending on the available materials to make my own mount…ill have to trade some weight to have correct safety margins.
Making my ringmount out of 2mm thick 304L stainless would result in a weight of 2.3kg (ring only without the tubes that go to the motor)
It seems light to me and making it out of 3mm thick wouldnt be soooo heavy… its would end up around 3.5kgs ring only. Then there are 8 sections of tube that go to the engines anchor bolts less than 20cms each…buts lets say they are 20cms each just for the calc… … i have 1.8mm 4130 tube for that… it may weight around 1.45kg according to my calculation.
A total of 5kg for my homemade ring mount. beign really safe with 3mm 304L main tube and 1.8 thick 4130 legs.
Posted: Sat Aug 27, 2022 2:06 am
by Kai
Ive seen someone making an adapter from a solid piece os 12mm steel… But i dont know…i calculated it to be around 3 kilograms for the plate only… Ill try to make something lighter without compromising strenght… (sounds easy XD)[/quote]
Yep- that was me!
Just to make it abundantly clear- the 12 mm thickness of the adapter plates was selected because of the aim to utilize (the already in stock) harder Sonex rubber isolators for the Jab33, as well as its mount. If someone could find 12mm Al 6061T6 or 7075T6, strength would not be compromised- at a lower weight. However, in this country, no such luck! The one big advantage of using the mount for the 33A, is that it pulls the Rotax as far back as possible (from heel to toe, with its standard ring mount, the 912 is even longer than the 33).
Everything said and done, the plane has been airborne for close to 50 hrs by now. So far, no nasty surprises- in fact no surprises at all. EW t/o mass with oil and coolant, but no fuel, came out at 309 kgs. The corresponding CG lies smack bang at 20% aerodynamic cord- the forward limit. The plane has been spun with 2 persons and half fuel: standard recovery works like a charm.
Posted: Sat Aug 27, 2022 1:42 pm
by xeriotti
Kai wrote:I
Yep- that was me!
Just to make it abundantly clear- the 12 mm thickness of the adapter plates was selected because of the aim to utilize (the already in stock) harder Sonex rubber isolators for the Jab33, as well as its mount. If someone could find 12mm Al 6061T6 or 7075T6, strength would not be compromised- at a lower weight. However, in this country, no such luck! The one big advantage of using the mount for the 33A, is that it pulls the Rotax as far back as possible (from heel to toe, with its standard ring mount, the 912 is even longer than the 33).Everything said and done, the plane has been airborne for close to 50 hrs by now. So far, no nasty surprises- in fact no surprises at all. EW t/o mass with oil and coolant, but no fuel, came out at 309 kgs. The corresponding CG lies smack bang at 20% aerodynamic cord- the forward limit. The plane has been spun with 2 persons and half fuel: standard recovery works like a charm.
Kai! Ive seen your work! It would be my option to do it just like you, but my engine didnt come with any mount at all… So…I have to couple the Aerovee mount to a plain Rotax.
What im trying to achieve is my own Ring Mount, with my own rubber damper sistem and Aerovee mount spacing. Im around 40mm forward of where the Aerovee prop hub would be…
Posted: Sat Aug 27, 2022 2:35 pm
by Kai
There is always more way than one to skin a cat!
This one (Pay particular attention the the square tube stiffener bar between the two upper aluminium attachment angles in the airframe) is done by a guy in Sweden- scratch built from the ground up. The amount of work must have been overwhelming!
Posted: Wed Aug 31, 2022 11:57 am
by xeriotti
My lasercuts are ready, my rubbermount housings too… no more excuses! start welding!
Laser is so exact! Love it!.. a few taps with a hammer are enough to maque everything fit perfectly. I assembled it with a few tacks and tried it on the plane to see if everything was OK
Like a charm ![]()
Heres the part that you can really screw things up… It isnt weld porn at all, but not bad for a mig running CO2
Penetration on the other side (keep in mind the rubbermount bushing walls are 3mm and the core is 5mm thick)
Welding it on the inside would be sufficient… But i welded the outside and will flatten it out later with an abrasive flapdisc
Im planning to add some ribs on the inside to reinforce it a little bit more…It might be overkill but i preffer those 300 extra grams of steel in there for my peace of mind ![]()
Posted: Thu Sep 01, 2022 10:45 pm
by xeriotti
This will bolt to the engine rear anchor points… Those are 10mm 8.8grade bolts.
The center reinforcing rib is ready. its so stiff i decided to go down on the thickness of the inside and outside perimeter.
Looks legit XD
Ready to start welding the perimeter and around the damper housings to close the “box”
Posted: Fri Sep 02, 2022 2:02 am
by Kai
Keep up the good work. This is getting interesting!
I am very curious to see what engine anchor points you will use, and how you will attach them to your ´ring mount´.
Your 40mm forward movement of the Rotax prop flange compared to the Aerovee is not something to worry about CG wise: my own 35mm did not turn out to be an issue. Another matter altogether is the standard engine cowling, which will be in for some drastic modifications. If like me you hate composite work- the best of luck!
It is obvious you have thought of something Rotax did not- accessebility to the water pump inlet albow: their own ring as good as blocks all attempts for a good hookup.
KEEP THE PHOTOS COMING!
Posted: Sun Sep 04, 2022 2:30 am
by xeriotti
This takes more measurements and calculations than expected… But its on its way!!!
Im going to use the four rear anchor points… And 2 tubes connectiong each to the “ring”…
Posted: Tue Sep 13, 2022 1:43 am
by xeriotti
Inner and outer TIG welded perimeter ready… It forms a box, looks really strong… Lighter than making it from aluminum, feels firm…
Posted: Tue Sep 13, 2022 7:53 am
by 13brv3
That’s a lot lighter than I would have guessed. Now for the fun part of adding the engine attachments.
Rusty
