AeroInjector Mixture Cable to Arm Attachment
Posted: Sat Jul 25, 2020 10:34 pm
by Spaceman
Howdy folks,
I just installed my AeroInjector “carb” (or whatever you want to call it), and I’m setting everything up according to the instructions that came with it. Page 13 talks about the mixture cable and how to install it, and specifically step 8 says to tighten the swivel nut enough to grip the cable but it should still freely rotate within the arm.
I have found that there is no tightness that holds the cable securely in the arm and still lets the swivel nut rotate within the arm as it moves! It looks to me like the hole through the swivel nut is too close to the arm, so when the set screw is tight it clamps the cable against the side of the arm and therefore it can’t rotate relative to the arm.
The result of this is that pulling the mixture knob forces the cable to flex (since it’s locked to the arm), so as soon as I let go of the knob it just springs back to approximately where it was.
If I loosen the swivel nut enough so it can rotate at all, it doesn’t hold the cable well enough and the cable just slips through when I move the mixture knob.
Has anyone else encountered this? It seems like if the hole through the swivel nut was just a little farther away from the arm (to the right, in the attached picture) then it would work fine. I guess alternately I could file the arm a tiny bit thinner to make some clearance?!
Thanks guys!
Re: AeroInjector Mixture Cable to Arm Attachment
Posted: Sat Jul 25, 2020 11:38 pm
Chris,
On those Azusa swivels I like to run a short screw in from the other side of the fitting in addition to the main securing screw. This allows the wire to be pinched between both these screws without wedging the control wire against the arm. This also works for the trim tab on the legacy Sonex trim tab lever setup.
Posted: Sun Jul 26, 2020 12:43 am
by Spaceman
Jeff,
Ah! I didn’t realize it was threaded from the other side! That might just do the trick. I will give it a whirl in the morning. Thanks!
Posted: Sun Jul 26, 2020 12:33 pm
by Spaceman
Sure enough that solved it! I picked up a #8-32 x 5/16 set screw from HD and used that. I had to run a tap through the swivel nut because the threads didn’t go quite all the way to the other end. I tightened the set screw enough to push the cable away from the arm within the hole, and then tightened the other screw snug against the cable. Now it works as advertised!
