AeroConversions Throttle Quadrant
Posted: Sun Jun 30, 2024 7:54 pm
by tmritter44
AeroConversions throttle quadrants provided by Sonex do not have enough cable pull length for UL350 engines. Initial trials on my Sonex-B are about 1/2" short. Has anyone devised a solution?
Re: AeroConversions Throttle Quadrant
Posted: Mon Jul 01, 2024 4:53 pm
I made the throttle lever longer and fixed the cable higher up on the lever so I could get the minimum 68mm throw required for the rotax, the co pilot side also seems to have no limit so copying that might also produce some ideas.
Posted: Fri Jul 05, 2024 10:56 am
by tmritter44
I followed Murray’s suggestion with good results. Moving pivot point for the throttle lever down & aft 7/16" added 3/4" of cable pull. Then attached push/pull cable to top of lever to reverse the action.
