Aerobrake puck and disc wear?
Posted: Fri Oct 13, 2023 6:08 pm
by 13brv3
Greetings,
I pulled the wheels and brakes today, and was surprised to see how much wear there was on the stainless plate they use as a single sided disc. The plate is worn to the point where the bolt heads are starting to wear. I think I read this somewhere before, but assumed it would take a lot of hours to get to that point. I’ve got just over 100 hrs on the brakes, but maybe only about 175 landings. Our runway is 6500 ft, and I make no effort to stop at the early taxiway, but rather coast to the far taxiway to save wear and tear on the brakes. Hard to believe they’re this worn, but I guess there just isn’t much surface area to work with.
I’ll order new parts (disc plates, bolts, pucks) totalling $183.50, though I may continue using these for a while longer. Does anyone have an unused puck handy? If so, how tall is it? Just wondering how much mine have worn. Mine are currently 0.37"-0.39" tall. The disc looks like it’s worn around 0.032".
Rusty
Re: Aerobrake puck and disc wear?
Posted: Fri Oct 13, 2023 6:45 pm
They are most likely designed to wear down below the bolt heads somewhat. Maybe reach out to Sonex and see if they have any minimum thickness advice.
Posted: Fri Oct 13, 2023 7:47 pm
by Waiex 0194
I’m putting my brakes together now. The bolts tighten up flush with the disks, becoming part of the braking surface. The pucks are .625 inch thick.
Posted: Fri Oct 13, 2023 7:59 pm
by 13brv3
Waiex 0194 wrote:I’m putting my brakes together now. The bolts tighten up flush with the disks, becoming part of the braking surface. The pucks are .625 inch thick.
Thanks for the quick measurement. I guess mine are 40% gone. I couldn’t remember about the height of the bolts, but I would swear the bolt heads were below the disc. I didn’t take any pictures of this installation, but on a previous installation years ago, the heads were clearly below. it would really make sense to have the heads flush though.
I’ll just place the order and see what the ETA is before making a decision on putting these back for now.
Rusty
Posted: Sat Oct 14, 2023 8:20 am
by Tony4aro
I’m still building, so there is no wear on my brakes. The bolt heads are just slightly lower than the face of the disk. maybe a 1/16"
Posted: Sat Oct 14, 2023 8:54 am
by 13brv3
Tony4aro wrote:I’m still building, so there is no wear on my brakes. The bolt heads are just slightly lower than the face of the disk. maybe a 1/16"
That sounds about like what I remember, and what I see in the old picture.
Rusty
Posted: Sat Oct 14, 2023 9:51 am
My bolt heads are definitely wearing. I had no thoughts of replacing the rotors yet though. They seem to have lots of thickness left.
Posted: Fri Oct 20, 2023 8:58 pm
by 13brv3
Has anyone tried to find other puck options for these brakes? I suppose Sonex might cut them inhouse, but I wouldn’t be surprised if they’re an off the shelf product for something else, like maybe kart racing.
I’m OK with Sonex price for the pucks, but I’d like some option for material. These are only described as “hard”, but that’s not super helpful. They seem to wear the SS disc pretty fast, so they must indeed be fairly hard. My brake force isn’t what I’d like it to be, and I wonder if a softer compound for the puck would help. It would certainly wear faster, but also wouldn’t wear the disc as much. Pucks are easy to change, so I wouldn’t mind the extra wear.
My usual go-to for material is McMaster-Carr, and if this link works, it will go to a page that shows material with 3 different friction options in 5/8" thickness. https://www.mcmaster.com/products/brake … ess~0-625/ I wish I knew where the Sonex pucks fit the friction range, then I might try making pucks with the next softer material. I wonder how long an end mill would last cutting brake lining material :slight_smile:
Rusty
Posted: Sat Oct 21, 2023 1:04 am
by Kai
Rusty,
Good idea!
Maybe some softer puck material could help. As it is now, stopping power is nothing to write home about, and the brakes will not hold the plane during ignition checks much above 3000 rpm, which is too slow for the Rotax. I´m not too concerned about premature wear- the wheels have to come off at least during the annual anyhow.
Kai
Posted: Sat Oct 21, 2023 9:56 am
by 13brv3
Kai
Exactly. I can just barely hold the plane at 4000, but it’s more effort than it’s worth, so I do my runups at 3000 as well.
I’m tempted to order the smallest size of the softest material. I do worry about the fact that the puck has to have enough mechanical strength to resist breaking at the edge of the caliper cylinder. I’ll probably send Sonex an email and ask if there are any specs on the material they supply, and if they have an option to get softer compounds.
Posted: Sat Oct 21, 2023 10:26 am
My brakes hold at WOT, probably an Aerovee benefit.
Posted: Sat Oct 21, 2023 2:02 pm
by 13brv3
Bryan Cotton wrote:My brakes hold at WOT, probably an Aerovee benefit.
LOL!
Posted: Sun Oct 22, 2023 10:07 am
by Kai
Probably…………
Posted: Tue Oct 24, 2023 3:54 pm
by 13brv3
I got a reply from Sonex about the brake puck material. The good news is that they’re using that same material I linked from McMaster-Carr. The bad news is that they’re already using the high-friction version, so there won’t be any room for improvement from those materials. It’s good to have the coefficient of friction number though, since I can compare that to other materials I might find.
Posted: Tue Oct 24, 2023 6:16 pm
by flyguy0609
Rusty,
" I wonder how long an end mill would last cutting brake lining material :-)". I love my end mil, but not enough to give her a name. :slight_smile:
Harvey Tool has end mills for everything. I would suggest you look at their end mills for composites.
https://www.harveytool.com/products/mat … ng%20tools
hope this helps
Posted: Tue Oct 24, 2023 7:22 pm
by 13brv3
I was mostly joking about the end mill. I’d just sacrifice cheap ones if I manage to find a suitable material.
The question now is whether we can find suitable friction material. It would need to be at least 5/8" thick, and the diameter of the pucks is 1-1/8". The stock material is listed as 0.55 max coefficient of friction, max temp 550F, and max pressure of 500 psi.
Posted: Fri Nov 03, 2023 8:44 pm
I have a couple if thick washers between the brake body and the wheel/bearing. Otherwise the brake pad and puck are in constant hard contact with one another. I have had my current pucks for 3 years and they are still in good shape, without need of replacement.
