Accident N390SG
Posted: Wed Jul 05, 2017 10:13 pm
Anyone have any more info on this? forced landing in field, and struck a fence. No injuries, but substantial damage. Plane built by patrick glazier. In eldon missouri. Plane registered to tom aliotta. Saw post on http://www.kathrynsreport.com. 3 july 2017
Re: Accident N390SG
Posted: Wed Jul 05, 2017 10:32 pm
by jjbardell
Revmaster turbo engine is all I know. Glad to hear the pilot had no injuries.
Re: Accident N390SG
Posted: Wed Jul 05, 2017 10:36 pm
Actual link: http://www.kathrynsreport.com/2017/07/sonexsonex-n390sg-accident-occurred.html
Re: Accident N390SG
Posted: Fri Jul 07, 2017 11:08 am
by tljones42
Postby jjbardell » Wed Jul 05, 2017 9:32 pm
I didn’t realize Revmaster was selling a turbo engine.
Re: Accident N390SG
Posted: Thu Jul 20, 2017 10:28 am
by taliotta
It has taken me quite some time to get signed up to reply to your post. I am the owner of N390SG and would love to tell you what happed. This Sonex is one of the best equipped Sonex out there. I am going to list the equipment because that is part of the story. It has the Dynon D180, AvMap, Dynon AP 74 Auto pilot, Becker radio, and the Micro air Transponder. The Revmaster has a Turbo with EFI and controlled by the SDS system (Simple Digital System). The SDS system is its Achilles Heel. Sure it will fly to 10,000 without loosing power. It never needs mixture control, you just start the engine wait until you have 110 degrees on the oil temp so that you don’t get oil blow-by from the Turbo, and go flying. No mags and nothing else to check accept the normal amps, volts, fuel pressure, oil pressure and so on. So it is only a visual scan of the instruments. I live in Central MO and took a neighbor for a flight to just bore holes in the sky. We climbed to 2500 ft and set the Auto pilot and I used the Bearing dial to change course. We did a square pattern and on the third leg I dialed up an Airport at the Lake of the Ozarks and headed to the lake. About mid point of the lake my radio and transponder just shut down, followed with the GPS a couple of seconds later. The Dynon became very static, and I notice that my volt meter and amp meter were pegged at the bottom. I turned off the Auto Pilot and entered a climb and headed towards the hwy since there is not a suitable place to land at the lake and all the terrain is highly tree’d. I lost the Dynon at 2,900ft and a couple of seconds later the Engine stopped with the prop horizontal. I put the nose down and flipped the AV master on and the Dynon came on for a couple of seconds so that I was able set my best glide at 70. I tried to restart but nothing at all. I had my passenger turn the fuel off as I shut down all electrical switches and concentrated on landing. As I turned at the Highway, I noticed a long grass field off to the right in a perfect distance to glide to so I chose that instead of trying to land with the 4th of July traffic. I flipped the AV Master just over the trees to see 67 mph indicated, put in full flaps and held it off the field until I bleed of my speed and touched down at 47 mph. This is a conventional airplane so I held the stick full back to maintain control on the tail wheel but I had floated a bit longer than I wanted and a barbed wire fence loomed about 50 ft in front of me but I was able to steer the plane between the T posts that hit each wing, and 10 feet after the fence was a drainage ditch about 2 ft wide and 10 inches which caused a partial collapse of the gear. I can’t say enough good stuff about the strength of the Sonex, the wings held up, and the gear kept me from going Turtle. We weren’t even sore the next day, because it was actually a very smooth landing. Thank you Sonex. Now about the Turbo. I didn’t build the plane, and I frankly don’t know where the builder got the Turbo from, but it worked great and I know that Joe at Revmaster is working on a Turbo unit as I write this. But the SDS System, while it is a fine unit, it is a weak link in the system. Had I had a carb with mags my engine wouldn’t have quit and I wouldn’t have a totaled airplane. I will never own or fly any aircraft that depends 100% on electrical power to fly. I have been a pilot for 29 yrs and this is my first off airport landing due to engine failure. I hope I have answered all your questions, but if there is anything else I can tell you, let me know, since I will a monitor this website a couple times a week. The Sonex and the Revmaster are both great products and that turbo was a bonus but stay away from the SDS System.
Re: Accident N390SG
Posted: Thu Jul 20, 2017 2:25 pm
by gcm52
Good piloting by the way!
Re: Accident N390SG
Posted: Thu Jul 20, 2017 4:01 pm
Hi tom,
Thanks for the update. Glad to hear no injuries. Can the plane be repaired? Can you post some photos?
Re: Accident N390SG
Posted: Sat Jul 22, 2017 8:14 pm
by kevinh
Thanks for the update!
Re: Accident N390SG
Posted: Sun Jul 23, 2017 11:09 am
by taliotta
I will try and post some pictures for you Michael. Yes, the plane can be repaired but the insurance Co. is totally it since the repair estimate is greater then what I insured it for. If I am able to buy it back from them, all I will need to do is redo the wing skins and landing gear, but I developed an oil leak for some reason, and I am going to get rid of that SDS system. I will probably buy me another Revmaster 2300, since it is an amazing running engine. It is very smooth and responsive and I may consider reapplying the Turbo to it, but I’m not sure at this point since I think the Revmaster product is fine the way it is, I just would like some more power. The customer support from Revmaster is wonderful.
I am unable to post a picture, I tried several times and my photo’s have to many pixels. Look me up on face book and friend me and I will get you pictures that way if you are that interested. Make sure you make it clear on your Facebook request that it is about the Sonex or I won’t accept the request as I get a lot of strange requests.
Re: Accident N390SG
Posted: Sun Jul 23, 2017 12:26 pm
by Direct C51
Taliotta, thanks for sharing. I was hoping you could elaborate on the electrical issue you had. I’m also going to be flying an airplane dependent on electrical power, so I am interested in this aspect. Could you clarify what caused you to be flying along without any problems, and then what sounds like seconds later your voltage was so low that your equipment was shutting down? Was there an electrical short on a large wire that caused such a rapid drain on the battery? You had to be down under 11 volts for your radio and transponder to shut down. I am hoping that if this was an alternator or charging failure, that you would have recognized it before your stuff shut down. Thanks for the insight.
Re: Accident N390SG
Posted: Sun Jul 23, 2017 1:43 pm
by chris
taliotta wrote:I
Email your pictures to me and I will post them for you.
Re: Accident N390SG
Posted: Sun Jul 23, 2017 1:49 pm
by kevinh
For anyone who is building an electrical dependent plane (which is a fine thing IMO) should read Bob Knuckols bible on the topic. It is free here: http://www.aeroelectric.com/Book/AEC_R12A.pdf or you can get a print or CD copy here http://www.aeroelectric.com/Catalog/pub/pub.html. It is a great simple way to get a reliable electrical system (either with a small backup battery or without). I used it when I built my RV.
Re: Accident N390SG
Posted: Mon Jul 24, 2017 7:36 pm
by lutorm
Glad you got out of that unscathed. However, with all due respect, I think you are drawing the wrong conclusion from the event. If you had had an engine failure due to a magneto, would you have said “I will never again use an engine that is entirely dependent on magnetos”? No, because even though it is, and magnetos fail disturbingly often, you have two of them and it would have been a non-event.
Similarly, if you have an engine with electronic ignition (or EFI), it seems prudent have a backup source of electrical power for the engine. Electronic ignitions are generally very reliable, but any number of events can take down your electrical bus. If you’d had a backup battery providing power to the ignition system, this would also have been a non-event. I believe the “Aero-electric connection” already referenced makes this point very emphatically.
Re: Accident N390SG
Posted: Tue Jul 25, 2017 9:44 pm
by vernd
Interesting note. Simple Digital Systems owner had this system installed in his own RV-6 with Subaru engine. He had a similar experience with loss of electrical power, resulting in engine failure and off airport landing. The following link has some information about his experience and what he did to remedy any further occurrences.
http://www.sdsefi.com/rv12.htm Scroll down to Feb 2005 for the story.
Lots of good information on their website about this product. To me it always looked like a good system
