2850 Corvair Engine Prop Diameter/Pitch?
Posted: Fri Apr 12, 2024 8:40 pm
by Wanttobuild25
if you have a 110 HP 2850 William Wynne Corvair engine in a Sonex, what would be the recommended diameter/pitch? How about pitch with extended gear legs allowing up to 60” diameter?
Thanks for any input,
Jeff Ackland
Re: 2850 Corvair Engine Prop Diameter/Pitch?
Posted: Sat Apr 13, 2024 8:40 am
by mbean
I have the same engine. Dan at Sport Performance Aviation LLC recommended 54"- 56" pitch for use on a standard gear length A model. Not sure if that changes if intending to use a longer prop. I suggest you contact SPA for further discussion.
Mike
Sonex #1694
Posted: Sat Apr 13, 2024 11:06 am
by Wanttobuild25
Thanks Mike!
