Trigger shaft assembly
trigger shaft assembly
Posted: Mon Jun 02, 2014 9:05 pm
by Sonex1414
I took the stator off and two of the ACV-Z01-36 cap screws that hold in the trigger shaft assembly were loose. One of them fell out. The stator had been rubbing on the screws. Obviously I can not put in a new 1/4 X 28 cap screw. I am going to have to up drill the hole and retap it. Has anyone done this and what did you use and how did it work out?
Re: trigger shaft assembly
Posted: Tue Jun 03, 2014 12:23 pm
by oynif
Excactly why not put in a new screw, is thread Damaged ?
Kurt
