Thoughts on adjusting the valves
Last night I changed the oil and adjusted the valves. A buddy of mine does them every oil change and has talked me into it. So that’s every 25 hours. It’s pretty easy, but I’ve gotten good at it.
  1. Start with #4. Then between 180° swings of the prop you do the right side and then the left side. Would also work starting at #2.
  2. Pull your feeler gauge out of the collection. I used to balance the rest of them on neighboring valves, but dropped it a couple times and the one I use got bent. Then it broke. It’s a lot easier to use with a single gauge rather than the full set!
  3. I pull on the rockers at TDC before I break the locknuts. I don’t bother to measure what the clearance is. It usually moves anyway. I just check if there is some clearance or if it’s tight.
  4. Set the lash while moving the feeler in and out. Sock down the nut with a box wrench and make sure it’s still good. Then torque it, and make sure it’s still good again. Only after that do you pull the feeler out. With a single gauge it stays there nicely.
  5. Flip the prop 180° while watching the next intake valve. It should be closing.
  6. I use silicone rubber gaskets. Link below. No sealer, I’m on my second set in 500 hours. They don’t leak. Plenty of leaks elsewhere though, so no worries.
  7. Safety wire those valve cover bolts!
  8. Have spare adjusters and locknuts. They do get messed up occasionally.
I had to trim off the little tabs on those gaskets. I’ve also got their sump gasket.
Hey Bryan, sounds like you have it down to a science. The 180 degree backwards swing of the prop makes it easy and quick. I typically Start at #4 too.
I’ ve been checking mine every 10 hours with that creeping #3 exhaust valve. Last time I checked all were still at .008" except #3 was at .0015 after 10 hours.
I do still check if they feel alright and don’t loosen the nut if they measure right. Then check the nut tightness to confirm its still on :wink:
