Primary ignition coils
After 1 hour of engine run time on my new AeroVee 2.1 with taxi time, The primary ignition will not quit. Switch both ignitions off and it keeps running fine. Secondary electronic ignition works fine and shows a mag drop when turned off. Tested P lead wires and switch checked out fine. Ohm meter tests of the coils from P-lead to ground is no continuity on one and 1.6 M ohm on the other. Looks like I need to replace both. Has anyone found a cheaper source than Sonex? After some searching, I found a Briggs & Stratton part number 440-441 that looks like the correct one. sleequipment.com has them for $37.99 compared to Sonex at $107.00
I don’t know anything about the ones you found, but I’ve used these Oregon 33-345: Amazon.com: Oregon 33-345 Ignition Parts, Black : Automotive .
I assisted a fellow several years ago on problems with constantaly burning up coils, on aerovee, with master off. would eventually drain battery. found he had wired the power to the electronic igniton to the wrong…always hot…side of the master contactor. I have had no further info on any other problems that he might have had. might want to revisit this area???
Joe, his issue is with the primary, not the secondary electronic ignition. About 12 years ago, there was a batch of faulty magnetrons that wouldn’t shut off. I had one.
