Hello everyone,
We created this thread for Onex builders to share their build progress, ask/answer questions, provide feedback and anything else on the subject. Enjoy!
Thank you for creating this, Casey! Given the number of people considering Rotax installations for their projects, having a location to discuss these installations will be a real benefit.
I’m currently working on Onex kit #245 in central Ohio and have installed a Rotax 912ULS I purchased from a flight school near Chicago. This engine ran 2000 hours in a Remos GX before I got it and sent to Cooper Aircraft for an IRAN/refurbishment.
I’ve been working on the kit for around 18 months and have ~600 hours into the build. I’m loving the build but I’m also looking forward to having it done and ready to fly!
Hi Michaelfarley56,
Always happy to talk about Rotax 912’s. I am on my second (diffrent aircraft) and have had outstanding performance, reliability and economy of operation, from both.
Back to your Rotax installation; I am concerned about the oil tank height, above the oil pump and its angle.
The height, of the tank above the oil pump, looks to be well outside the Rotax specifications. This may have an unknown effect on the oil flow and on preflight cold oil return to the tank (“Burping”)
The angle of the tank is going to make oil level assessment difficult and may adversely effect oil/gas returning from the crankcase separation.
I strongly recomend you join the Rotax Owners Forum. In addition to excellent debates, you will have access to genuine expert advice, all the manuals relevant to your engine and on advisory/mandatory directives from Rotax.
Hi Michael,
Good to hear from you. Great job on the onex! Hopefully see you at airventure 2027. Sonex embracing rotax, jabiru, UL on all models was a huge upgrade. Keep posting! Youve seen mark ferstl onex , finished
by casey , with the rotax install. My father was his tech counselor in tucson before his passing. 2023.
Continue on!
michael.
I appreciate your input. I’m not a huge fan of the oil tank location, but I am including the tri gear mount portion of the engine mount for future use and as a result, there is nowhere else for the tank to go. I guess we’ll see how well it works!
Good to hear from you, Michael! I’d love to be at AirVenture 2027 but we will see how the remainder of the Onex build progresses. Cross your fingers!
I’ve talked to Mark multiple times and was looking forward to seeing his Onex at AirVenture this summer, but Mark wasn’t able to make it due to the weather. I hope my Onex is almost as fast as Mark’s! He’s getting a ton of speed out of the airplane.
