Engine don’t run well when hot
Posted: Wed Oct 14, 2020 10:28 pm
by Pomec
I have a 2276 with an aeroinjector, it’s run well on flight but when I land it’s running very roughly on idle.
My 2 mags are ok
Thanks for the help
Re: Engine don’t run well when hot
Posted: Thu Oct 15, 2020 12:23 am
by lakespookie
With out any additional data it is very difficult if not impossible to really give you solid advice, I would start with pulling plugs and seeing what they look like maybe going lean or rich on the ground depending on your installation. How are your temps, I am not a huge fan of compression tests but it would not hurt to see if you had a totally dead cylinder or bad valve seat that may be somoothed out at higher RPM or Engine Loading. You could also have a timing issue mags might be fine but the timing may be slightly off in idle or under minimal loading.
I am sure others will have other possible things you can look at but honestly its just a shot in the dark.
Posted: Thu Oct 15, 2020 8:28 am
by Pomec
It’s a new engine
Lot of power on hi rpm
Posted: Thu Oct 15, 2020 9:31 am
by tx_swordguy
2 possibilities, both fuel related. one you are getting “the burps” look it up. The fix is basically getting rid of the gascolator and insulating the fuel lines. Two, you need to adjust/change your needle because you are either too rich or too lean at idle. I tend to think it is the second one. You cannot leave your mixture in one place from full throttle to idle with the aeroinjector. I have found it better to lean to the point of dying at idle.
