I’d like to get a compression tester extension to make compression testing easier. They basically screw into the 12mm spark plug hole, stick out 8-9” and have a nipple at the other end to connect to the tester.
Has anyone used one on their jab and if so which one did you purchase?
Spruce has a few listed that may work but it would help to know if someone already uses one that does in fact work.
And no, I’d prefer not to make my own.
Rotax has 12mm threads and Spruce sells a kit with extension and it works well on a rotax at least. Maybe check them out.
Here’s another option from Aircraft Tool Supply.
Bill
You must be peeking in my hangar as I’m starting my condition inspection and will be doing some differential compression testing … likely today.
I have and use an OTC unit:
Amazon.com: OTC 5609 Cylinder Leakage Tester Kit with Storage Case | Quickly Diagnose Internal Engine Problems like Bad Rings, Valves, and Leaking Head Gaskets : Automotive
Note the hose that comes with it. It is stiff but still has some flex to make it easier to fit into a tight space or where there may be the need to go over or around an intake, baffling, etc.
Don’t know if that particular hose can be had separate but I did find this:
Amazon.com: CTA Tools 2011 Compression Tester Adapter, Compatible with Ford Triton Engines, 12mm and 16mm Threaded Ends, 8-1/2" Flex Hose : Automotive
Dunno if this helps,
BTW: For the record - this particular OTC unit has been an excellent tool for many years.
That extension tool looks great. The hoses are a pain. I wonder if 12mm Rotax is the same as 12mm AeroVee.
Note that link has two tools, the first one is too short for my application. Need to scroll down to the long one.
Thanks all! I think I’m going to try the ATS extension (available through both Spruce and ATS direct). It may be a little while before I report back as my annual isn’t due for another 2 months and I just reinstalled the ram air cooling ducts again for now.
Careful while doing differential compression testing by yourself. 5 weeks ago the prop got away and left me with a broken arm needing surgery
Ohhh … sorry to see that! I did my differential compression testing today on the Corvair. Just as I was beginning a few folks showed up and wanted to chat and look at the plane.
I warned all of them that the prop was hot and to stay away until I could get the pressure off of it. Don’t need distractions while doing this. Good news was, they didn’t stay long.
On my engine it’s quite easy to see the piston at TDC and get a good prop position before attaching the hose ( I can’t use straight in because of baffling) and bringing up the pressure. I can then “rock the prop” but being always ready to “break & run” in an instant.
Your warning is very welcomed and a great reminder that safety is paramount and sometimes when we do everything right … things can still go wrongly.
Best,
So sorry to hear that Scott. I hope the best for your recovery and thanks for the warning.
Whoa… we did the compression checks at the Arion Aircraft Jabiru class this spring. The caveat was always beware. That is a rough one. They had us pull the prop through to try and understand the consequence that could happen.
Very sorry to hear about your accident.
I know a 60 something lifelong A&P that let an O-540 get away from him while doing a compression test. It wrecked his shoulder which required surgery.
Moral of the story, be careful, it can happen to anyone.
