I have a SonexB, with a Gen4 Jabiru 3300, AeroInjector with a #2 needle. What are typical CHTs and EGTs that people are seeing? Climb out, cruise? I’m still trying to get my CHTs down (focusing on CYL #1/3/5) to a more comfortable range. EGTs look good. Recently made a small trim to my upper cowl that helped.
My CHT on #3 is the only one that ever really gets my attention. On hot days during initial climb it will go over 310° fairly quickly. Even in cruise, it runs at or just above 300° if I am down low.
I’m running a Bing carb so it isn’t a one for one comparison
The rest are usually in the upper 270° to 280° range.
Recently I had one of those interesting learning moments. After some minor maintenance, when I put the cowl back on I omitted the bottom rear cowling pins at the lower fuselage. Did a short test flight and my temperatures were much more even and #3 was happy as could be. This makes me think I can open up the lower cowling a bit more or maybe add side vents.
Edited to add - EGTs have been within 100° of each other in the 1200° range if I recall. I tend to look at them as a relative indication, not an exact science. My opinion.
One other thought. I added a small deflector inside the baffling right above #3 after early flights had CHTs much higher. It helped immensely
I had enlarged my bottom cowl vents early on. Rigging a small block along the lower edge like you mentioned would be an easy and quick test
