Back Up ASI
Back Up ASI
Posted: Fri Jun 24, 2022 6:25 am
Hi All,
My new Sonex has an all digital panel - have been thinking - what if I have a major power failure to the panel & everything goes black ? True its an unlikely scenario, especially as I already have a back up battery for such an occurrence. BUT WHAT IF ?
Seems to me I can pretty well fly the aircraft without any instruments - just attitude & power BUT once I get into the circuit/start to slow for a landing, everything MAY start to get a wee bit stressful.
What instrument(s) might improve the situation? Do you agree that an ASI is the minimum that I would need to ensure a safe landing?
I have very limited panel space, so I think I will limit my back up ASI to 57mm (2 1/4")
The important speeds will be those that assist with landing, so the minimum should be 35-110 Knots. Most gauges operate best in the mid range, so a gauge that indicates 20-120 knots should be just about right.
So what would you recommend?
So far I have looked at;
SWIFT 10-06293
LXNAV Airdata Indicator
Falcon ASI120N-2
Midcontinent MD 25-160
UMA 16-211-120
Re: Back Up ASI
Posted: Fri Jun 24, 2022 6:58 am
by pilotyoung
I just put a new all digital panel in my Onex. I have been flying an RV-12 with an all digital panel for 4 1/2 years. My friends sometimes ask me what I am going to do if the power goes out. I tell them, Look out the window, fly the airplane, and land it somewhere, hopefully on an airport.
When I used to teach students, before I would let them solo, I would cover up the six pack of instruments and tell them to fly the pattern and land. The first reaction was I can’t, I don’t have an airspeed indicator or an altimeter. I told them fly the same attitude and power settings you have been flying. You know those, fly them. I never had one crash.
So I am totally comfortable flying an all electric airplane. If you are not, get with a CFI and have him turn off the digital instruments just before you enter the pattern and land. Do it several times and it will give you confidence. If you are still not comfortable, add an airspeed indicator.
Re: Back Up ASI
Posted: Fri Jun 24, 2022 8:18 am
pilotyoung wrote:I just put a new all digital panel in my Onex. I have been flying an RV-12 with an all digital panel for 4 1/2 years. My friends sometimes ask me what I am going to do if the power goes out. I tell them, Look out the window, fly the airplane, and land it somewhere, hopefully on an airport.
This is excellent advice.
You don’t see your average Certificated aircraft come with an extra ASI or any of the other instruments in the 6 pack. We don’t fly a Sonex with two engines (though we DO have dual ignition systems). It’s a weight/cost/risk analysis. Which is not to say that you can’t decide to put another ASI in if you bend your risk analysis that way if you are so inclined.
Re: Back Up ASI
Posted: Fri Jun 24, 2022 9:38 am
My AOA/ASI reads from 70 mph to 0 with stall speed indicated at the beginning of the red area. Green, yellow, and red aeras on a differential pressure gauge. The probe is non-electric and home made from internet plans. A friend has made 3D drawings of the probe and makes them on a 3D printer. It even makes the pipe tap in the tubing connections. I use the AOA every time I land. It’s in my line of sight on the left top of the panel. If you practice tight 180 degree turns you will be surprised how close you come to stall in a 2G turn. It’s the only instrument necessary , and will help you make better landings. Wouldn’t fly without one. Total cost about $75.00
Re: Back Up ASI
Posted: Fri Jun 24, 2022 12:09 pm
Onex107 wrote:My AOA/ASI reads from 70 mph to 0 with stall speed indicated at the beginning of the red area. Green, yellow, and red aeras on a differential pressure gauge. The probe is non-electric and home made from internet plans. A friend has made 3D drawings of the probe and makes them on a 3D printer. It even makes the pipe tap in the tubing connections. I use the AOA every time I land. It’s in my line of sight on the left top of the panel. If you practice tight 180 degree turns you will be surprised how close you come to stall in a 2G turn. It’s the only instrument necessary , and will help you make better landings. Wouldn’t fly without one. Total cost about $75.00
I agree that a pilot must be able to fly the plane without a reference to instruments. Having said that, what is said here not only answers the question asked, but gives not only a backup to the ASI but another really neat tool in the panel and something that just may, in an emergency situation, keep a pilot from stalling & falling.
I’ve installed an LRI (Lift Reserve Indicator) on the last two Sonex aircraft I have owned and I believe they are worth their weight. I also have the mechanical type and on my current plane it has been flawless for 10 years. Highly recommended!
Here’s an approach (during flight testing many years ago) and you can see it on the left of the panel:
https://www.youtube.com/watch?v=WjA7JDJVKeQ
Re: Back Up ASI
Posted: Fri Jun 24, 2022 12:24 pm
I will echo sentiments above on adding mechanical AOA or LRI to your panel. It will not only provide you a backup for airspeed in the slow flight envelope, it will provide you with additional information that’s extremely useful in all low-speed/high-aoa stages of flight. In other words, it’s BETTER (and cheaper) than a backup Airspeed indicator.
Here’s a video I made awhile back demonstrating my LRI.
https://youtu.be/7aVS91ogf1c
Re: Back Up ASI
Posted: Sat Jun 25, 2022 10:32 am
This has become my new pet peeve during instruction and flight reviews. LOOK OUT THE WINDOW! The attitude of the airplane will tell you everything. Practice it a bit. The nose should NEVER go above the horizon until the flare. If its level, speed is good. If the nose is below the horizon, you have energy to spare. If the nose is above the horizon, you better be flaring for landing. If your Space Shuttle panel quits, don’t try to land on that 1000’ foot strip unless you have done is hundreds of times without reference to your ASI. Proper training and a little practice should be able to talk you out of back-up instruments. And our stuff is pretty reliable these days…
Re: Back Up ASI
Posted: Sat Jun 25, 2022 4:58 pm
One other reason for an old style mechanical airspeed gauge (and or LRI) On my GRT Sport SX, the large numerical airspeed display that immediately catches one’s eye on a quick scan, updates too slowly for a Sonex. It does have a tiny white arrow that moves up and down the linear scale in real time, but you have to look for it. I use my old mechanical airspeed indicator on all landings (and an eye on the LRI.)
Re: Back Up ASI
Posted: Sat Jun 25, 2022 7:43 pm
Great responses, my thanks to you all.
A few months back, I had been considering an A of A - I will now revisit that subject.
To the advocates of flight without reference to instruments:
Some of your responses lean toward normalising (arm chair response) an emergency situation - non of us know for sure how we will react (that’s why its an emergency).
In my view having a still functioning instrument(s) will greatly assist the pilot to achieve a good outcome.
Most of us, who have accumulated a few flight hours, can fly our aircraft without reference to the panel (when the aircraft is performing as expected) but we ourselves are not “configured” for flight so rely on artificial senses/instrument to achieve this state.
Try to put yourself in the situation where you have no flight instruments (may have additional problems), the need to make a safe landing, possibly into a paddock, which could include a tail wind component - a functioning flight instrument ASI or AoA might just be the critical factor in a survivable or not, result.
Re: Back Up ASI
Posted: Sat Jun 25, 2022 8:04 pm
Some of us have had airspeed failures and survived. I had a pitot cover freeze on a C140 once. My L33 Blanik used to frequently get water in the system. It’s not hard to deal with as long as you are not IFR.
The probability of a dual emergency, loss of airspeed AND having to land in a paddock with a tailwind is probably extremely remote.
With that said, if you want it, and it makes you more comfortable, by all means put redundancy in.
Re: Back Up ASI
Posted: Sun Jun 26, 2022 10:36 am
I put a backup MGL ASI/ALT in case I lose my efis or all power and I can switch it from the main bus to a 9v battery with a panel mounted switch. I slso have the reserve lift indicator.
Re: Back Up ASI
Posted: Sun Sep 04, 2022 9:23 pm
Bryan, I am a dedicated convert from GA to Recreational Aircraft Association Australia (RAAus). Did some flying in a Citabria recently - felt like flying a tank.
My personal view of RAA class aircraft is that the KISS principal should be, wherever practical adhered to. Some RAA pilots seem to try and get their aircrafts level of system redundancy up to or better than GA - I don’t understand this (unless its a bragging issue). BUT where a cost effective nil impact on performance safety enhancement can be implemented, I tend to go for it.
My new Sonex has come to me with a level of systems sophistication I never aspired to - not suggesting for a moment that I will undo the “package” I have purchased.
I have researched installing an A of A compatible with my Dynon - seems to be a simple cost effective enhancement that would improve my aircraft safety, particularly when attempting a landing on marginal field. Unfortunately the systems I have looked at would require significant changes to my pitot mounting - so something that may happen in the future.
The installation of a small analogue ASI, cost not too different from the A of A mast, will, in the event of a Dynon failure, give me all the information that I might need to get me down & stopped all in one piece. In the short term I think this will be the way I will go.
As for finding oneself landing down wind - most of my flying is over heavily treed, undulating to precipitous, terrain with only the occasional small field. An engine out would see me looking for the open space that I felt I could put down in with the greatest chance of my survival and secondly least damage to the aircraft - this could quite easily involve a down wind landing . When I fly out west the country opens up into larger flatter terrain, infinitely more options for a successful “out landing” I could even be picky about which 1000 acre field I might like to put down on.
Re: Back Up ASI
Posted: Mon Sep 05, 2022 9:50 am
There are plans for a standalone AOA on the internet. It does not use your pitot and does not use power. I built my probe out of scrap alum. The only expense is a differential pressure gage, less than $100 here. It does have to be mounted somewhere easy to see when landing. After 350 hours in my Onex I wouldn’t fly without one in any airplane.
Re: Back Up ASI
Posted: Mon Sep 05, 2022 10:53 pm
by onex28
Hi Morris, what degree do you have your AOA SET AT?
David W
Re: Back Up ASI
Posted: Tue Sep 06, 2022 8:44 am
Onex107 wrote:There are plans for a standalone AOA on the internet. It does not use your pitot and does not use power. I built my probe out of scrap alum. The only expense is a differential pressure gage, less than $100 here. It does have to be mounted somewhere easy to see when landing. After 350 hours in my Onex I wouldn’t fly without one in any airplane.
You can find a write up of the LRI here
https://img1.wsimg.com/blobby/go/e83c7c … 4222140376
https://sonexfoundation.com/safety-%26-education
Re: Back Up ASI
Posted: Tue Sep 06, 2022 12:09 pm
onex28 wrote:Hi Morris, what degree do you have your AOA SET AT?
David W
The angle of the probe is adjustable. It’s mounted on the inspection plate on the left stub wing. I don’t remember exactly but it’s somewhere around 53 degrees I think. I adjusted the angle until when it stalled the gage was just inside of the red area. This is 46-47 mph. The gage comes off the peg at 70 so the green and yellow areas are used primarily on approach and landing. But, doing high speed turns, 360’s, 2 G’s, you come very close to a stall also.
Re: Back Up ASI
Posted: Wed Sep 07, 2022 11:19 pm
With Reference to the A of A Plans, Page 10, Drawing
  1. Why is the mast angled forward?
  2. The two inlet holes seem (from the drawing) to be aligned - same forward location and parallel to air flow ?
  3. If my observation of 2 is correct, could the mast be vertical?
Re: Back Up ASI
Posted: Thu Sep 08, 2022 1:25 pm
The holes are parallel but located on 45 deg. surfaces. When the wing increases it’s angle of attack, the pressure on the holes unbalance and the differential pressure indicates how much angle there is. When the wing stalls, the pressures are the most different.
Re: Back Up ASI
Posted: Thu Sep 08, 2022 9:04 pm
Onex107 wrote:The holes are parallel but located on 45 deg. surfaces. When the wing increases it’s angle of attack, the pressure on the holes unbalance and the differential pressure indicates how much angle there is. When the wing stalls, the pressures are the most different.
Have you looked at other A of A’s - The Dynon doesn’t require a 45 degree angle surface but if memory serves the lower port is set at 45 degrees to the upper.
Re: Back Up ASI
Posted: Fri Sep 09, 2022 4:07 pm
by onex28
Thanks Morrie, I’ve started at 60 degrees and will drop to 53. I shortened my wingtips (19 feet wingspan now) so my adjustment may be slightly different than yours. Now I have to find out why my ADSB stopped reporting altitude.
