B model flap stops?
Does anyone have experience on whether or not adjustable flap stops are needed/used on the B model with the electric actuator?
I installed them and then took them off because they aren’t actually doing much. The B model flap torque tube is much more symmetrical between left and right and also not much distance for the torque tube to twist. The other thing with it is the electric flap actuator has too much force and will try to push the adjustable stop into the flap skin, ask me how I know this…
Good to know thanks! Seems like the rigidity of the newer design eliminates the need for manually adjustable stops?
