AeroVee performance issues
Posted: Sun Jun 05, 2016 8:28 pm
I used to have the ground adjustable prop. Now I have the recommended 54" Sensenich. With both props my climb performance has been anemic and quite scary, especially at gross weight. I don’t know if there is anything anyone can suggest but let me tell you what kind of numbers I’m seeing and perhaps you will think of something.
I’ve rebuilt the engine a couple of times (replace Nickasil cylinders with cast iron, and after replacing the crank and bearings from a prop strike). All 3 versions of the engine have run with the same numbers. While always seeming to under perform a bit compared to some other AeroVees, the numbers appear to be within specs, so I think I’ve built the engine well and haven’t done anything to compromise performance. I have the wheel pants and gear leg fairings (tail dragger) installed.
My #1 cylinder always runs hotter than the others. EGTs often run about 100 deg higher than the others (even #3). CHT also run hotter, often around 50 degrees. This has been true in all three engine builds. I have installed a metal deflector in the cowl opening to deflect some air away from #2 and back to #3 but that has not seemed to do much if anything. My cowl seals are all tight and the super tin and baffles are in good shape and installed where they are supposed to be.
The #1 and #3 cylinders have always run leaner than the front two, which is easy to see when you look at the insides of the heads and at the spark plugs.
During run-up, turning off the secondary ignition yields an rpm change of 0-20 rpm. In flight if I turn off the secondary ignition I don’t see any measurable change in temperatures.
After the winter I richened my mixture. During my last flight the engine was running a bit hot, and the #1 cylinder is what dictated how I climbed and how I adjusted the mixture. Since it was running hot I kept the mixture close to full rich most of the time. When I got back home and put gas in the tank I had burned 9 gallons for 2.2 hours of flight, so my fuel flow was 4.09 gph. So I think I’m still running too lean. I’m going to richen the mixture another 1/8 turn and see what happens. But if I run full rich on takeoff I often get an rpm drop, so leaning the mixture at least a little seems to give the best rpms.
There were times on this last flight where the #1 EGT was at 1380+ but the CHT was at 365. I usually see 390+ on the CHT if the EGT is correspondingly high. So I’m not sure what to make of that. But it wasn’t consistent like that.
The climb with the prop is still pretty anemic. I now tend to get off the ground, build up speed in level flight, then pull back the stick and climb past the 60’ trees at the end of a 2,700’ paved runway (at 270’ MSL). I’ve altered my first fuel stop on the way to OSH this year so that I won’t be taking off toward Pennsylvania mountains like last year (and scared the crap out of me!). I have been keeping track of my performance numbers. On my last flight:
Climb out = 3,150 rpm at about 200-250 fpm
  • Weight 961 lbs (Plane 655 lbs, me 190 lbs, full fuel 102 lbs, smoke oil 3 lbs, tool bag 11 lbs)
Climb to altitude:
3,030 rpm, 250 fpm, 72 kts, 68 deg OAT (took me 20 miles and 20 minutes to climb to 5,500’)
Cruise 1:
3,130 rpm, 5,500’, 93 kts indicated, 63 deg OAT (if I bumped up the rpms my #1 cylinder temps went up, but if I richen the mixture maybe I can bump a little more out of the rpm and airspeed, but 93-96 kts is about all I can get right now. With my old prop I was at 105-107 kts but the climb was just as bad.)
Cruise 2:
3,160 rpm, 5,500’, 96 kts indicated, 57 deg OAT
Maximum RPMs in level flight, if I ignore the high EGT/CHT numbers, is about 3,250 rpm.
Another AeroVee owner noted:
I see around 600 to 700 fpm when flying solo with full fuel at around 80mph on climbout. I don’t have the tool bag or smoke oil but am at 667lbs empty so it should be about the same.
So I don’t know what might be up, but flying at gross weight is downright scary, as there is very little climb performance. Often I see 3,150 rpm and 100-150 fpm, and my #1 and #3 cylinders are all bumping up into the red.
Any insights would be appreciated.
Mike
Re: AeroVee performance issues
Posted: Sun Jun 05, 2016 11:26 pm
by radfordc
mike.smith wrote:I used to have the ground adjustable prop. Now I have the recommended 54" Sensenich.
On my last flight:
Climb to altitude:
Cruise 1:
Cruise 2:
I know I’m just telling you what you already know…You’re numbers are far out of whack with “normal” that I can’t even guess what is wrong.
You’re engine is turning the correct rpm on takeoff (3150) but is at least 200 rpm low at max level flight.
You’re rate of climb is at least half of what you should see turning the prop at 3150 on takeoff. You’re cruise speed is at least 5-10 kts slower than it should be at the rpms you’re turning.
At 1200 lbs gross my Sonex would still climb better than 250 fpm.
You’re sure of the instrument indications?
Posted: Sun Jun 05, 2016 11:50 pm
by rizzz
I’m no expert but from what I gather it is the choice of camshaft that determines at what RPMs your engine will output the most torque.
Maybe you have an incorrectly ground camshaft, or perhaps Sonex accidentally shipped the incorrect type? I believe the one they normally ship with the AeroVee is a CB Performance Eagle 2234, this is very similar in lift/duration to my Engle W100 and as I’m told a good choice for engines running the sort of RPMs we do.
The race car guys will use totally different camshafts as they run much higher RPMs…
Posted: Mon Jun 06, 2016 9:05 am
by radfordc
While the engine could be the problem there is still something strange. If you have two identical planes turning the same prop at the same rpm, they should perform the same…no matter what engine is installed.
Mike’s plane is climbing slower and has slower cruise speed than “normal” Sonexs do. At the gross weight and rpm’s he is seeing the plane/prop should have more performance.
The fact that his engine seems to develop normal climb/cruise rpm, but doesn’t give full max level rpm is also strange.
I’m stumped.
Posted: Mon Jun 06, 2016 12:26 pm
by JohnF
Mike,
Have you verified the accuracy of the tachometer?
Just a thought,
John
Posted: Mon Jun 06, 2016 1:46 pm
by achesos
Hey Mike,
I’m interested in your solution since I’m about to complete first flight with an AeroVee taildragger that is 667 empty too…
As much as we want to believe these are all the same, I wonder if your 80.0 HP engine has the same output as my 80.0 HP engine? My point is that they won’t be exactly the same - the odds are against us that they can be exactly the same. I believe that this will also apply to the airframes themselves too - no two exactly alike - only approximations of the design/plans with some measurement error and tolerances all stacked together into the final assemblies.
So I agree that it makes sense to check your instrumentation, but it seems to be a fact that you want better climb performance no matter what some of the other gauges indicate.
I’m not smart enough to design a plane, so I stick to the basic principles smart people have identified for me. I vaguely remember that the enemy of thrust is drag…
Not to cast stones, but I wonder about rigging and other parasitic drag issues being a problem? Maybe a little fitment here and there or a gap seal somewhere special will clean things up and make it perform more typically? I stare at mine and wonder: “Is this good enough?”. At this point, I’m still simply hoping that mine will fly straight and fast (okay, reasonably fast in the not too distant future).
Please keep us updated on what you identify, test, eliminate and confirm. Good luck.
Sean
Posted: Mon Jun 06, 2016 3:24 pm
by n982sx
My take on your numbers.
First some actual numbers from one of my latest flights for comparison.
OAT
Ground 600’ msl 82, 2900’ msl 70 Gross Wt 990
Climb
RPM 3170
IAS 78 kts
FF 6.9 gph
Rate of climb 448 fpm
Cruise 2900’ msl
RPM 3150
IAS 103 kts
FF 4.4 gph
These are nominal numbers for me at about 30 pounds heavier - 990 - than you. At max gross - 1150 - I recently climbed direct to 5500’ msl with the following set of numbers. Maybe not quite the same climb profile as you but, close enough.
OAT
Ground 650’ msl 84, 5500’ msl 66
Climb
RPM 3150
IAS 80 kts
FF 6.5 gph
Average rate of climb 290 fpm for 15 minutes
Initial two minutes of climb 420 fpm at 74 kts
I have an MGL unit that records all my flight data and it includes a fuel flow meter. I also am running the standard 80HP Aerovee and prop, the same as you.
As you can see, on initial climb out, at the same RPM, but at max gross I’m getting just over a 400 fpm climb. I usually lower the nose a tad just for cooling after the first 400 feet, but I have no mountains to hit around Chicago, so I don’t worry too much about climb rate after that. I usually reach 400’ between 35 and 55 seconds, depending on temperature and weight. >600 fpm is common below 55°oat and just me in the plane.
Looking at my cruise data, you may be right in thinking that you are running too lean. I don’t know how reliable you feel your fuel flow numbers are, but I run richer than you indicate. Have you performed the 100° EGT temperature drop test in the air? If so what are your results?
I also don’t know how many hours you have on your Aerovee, but I never could get the prop to turn faster than about 3250 in level flight for the first 75 hours or so. The engine seems to gradually loosen up over time. Recently I was cruising along at 118 kts at 3380 rpm and 5.5 gph. I’ve been able to achieve these numbers since after about the first 100 hours or so. I’m up to 395 hours now.
Since your rpm’s don’t seem that off let me ask an obvious question. Are you running with gear fairings and wheel pants installed. Your numbers are more like I might expect if they were not. If you are, I would suspect your rpm indications are higher than actual, other than that I can’t come up with what might be wrong.
Posted: Mon Jun 06, 2016 3:32 pm
Any chance you have a clogged static port? It might have an effect of causing you to think you are slower than you are on climb out and climb at a shallower angle while simultaneously indicating a low climb rate. Seems unlikely that this would be the problem, but if I were in your position, I’d probably test it. Connect a tube (or syringe?) to the static system and roll up the end and verify that the system responds faster than you could possibly climb.
From your description, it does sound like you are tuned leaner than I am. I do have to lean a bit to get full RPM on climbout, but if it wasn’t tuned that way, then when I level out and the RPMs increase, the engine will become too lean. I do have a different propeller, though, and get closer to 2900 rpm on climbout and 3150-3200 in cruise. FWIW, I never have to limit my throttle in cruise to keep temperatures down.
Your old 105-107 knots in cruise at 5,500 feet doesn’t sound too bad to me. My airplane gets slower the higher I get and I do around 120 knots at 1500 feet or so. Once correcting for altitude and temperature, your number seems reasonable. I really wish I understood how Sonex gets 150mph at 8000 feet.
Posted: Mon Jun 06, 2016 7:34 pm
by Corby202
I do not know the full facts but if this engine was mine the first thing would be to confirm the indicated rpm was correct. Assuming that is correct, can you get at least 3000-3100 rpm static if not and everything on the engine is correct, it could be to much pitch on the prop. This would also account for the higher temps.
Posted: Mon Jun 06, 2016 9:11 pm
Hi, everyone:
Thanks for the input. Knowing what numbers others are seeing certainly helps figure out where the issue might be. I really have two issues that are, and are not, related: HEAT and CLIMB. Here are some bullet points based on all your comments:
  • My pitot static was just checked when I did my xponder check, and they were dead nuts perfectly calibrated.
  • I have the wheel pants and gear fairings installed. I have since day one.
  • I have rebuilt the engine twice. Overall it has 160 hours on it. With the new cylinders and bearings it has 20 hours. Maybe in another 20 or 30 hours things will improve?
  • But climb performance has been poor for the whole two years I’ve been flying.
  • I’ve never found anything out of rig or trim. I’m happy to have others look, but there is certainly nothing obvious. I’ve never experienced any off center ailerons or draggy flaps. I have the fairings at the roots of the flaps so the flaps don’t travel upward. If I look out at the wings during flight I don’t see anything at the flaps or the ailerons that looks out of place.
    -Having taken to heart much of what Mike Busch has written, I do try to use the EGTs as more of a guide than an absolute. It’s the CHT’s that I take great care to keep under 400 deg at all times. Except for #1, my other 3 cylinders usually run in the low to mid 300’s.
  • When I look up inside the cowl openings on the ground, all the baffles seals are tight to the cowl. I suppose it’s possible that the forced air could lift the cowl during flight. I think only a camera inside the engine compartment could show me that.
  • I was pretty much a stickler for following Sonex’s instructions. I followed the measurements for inlet openings as shown in the AeroVee manual.
  • I used the recommended 12.5"x4" outlet with the aluminum dam at the leading edge.
  • When I first built the engine and ran it, things were running hotter than I would have liked, but still in the green. When I was checking my fuel burn I was down at 3gph or a little more. This was way below where it should have been. I messed around with the needle settings but things started running rough. I changed to another needle and have been running very well ever since. But I spent the first 50 hours or so running way too lean. When I did my first annual my compression was awful, so I removed the heads and took them to a shop. They showed me how the valves were burned from running too lean. I suspect that all happened in the first 50 hours. Ever since then I usually average about 4.5 gph. So to me, 4.09 gph is too lean and may be part of my heat problems. It can’t hurt to check so I’ll richen the mixture a bit and do some tests.
  • As a rule, #2 and #4 run very close to one another, and are way in the green. #3 is hotter than #2/#4, but still about 30 or 40 degrees cooler than #1. I have checked for induction leaks many times. The only thing I have not tried is squirting flammable fluids around the areas prone to induction leaks. I suppose that’s next.
  • My empty weight hasn’t changed measurably since I weighed it 2 years ago. I measured it on calibrated scales from my EAA chapter. I got rid of the Nickasil cylinders so gained some weight there, but then I replaced the lead acid battery with a Lithium battery, so got much of it back. I’ve added a fuel flow transducer but that added only several ounces. Other than that I haven’t changed anything. If I’m off in my current empty weight I would guess it’s only by 5 lbs or so. Nothing drastic.
  • Regarding my posted climb numbers at 72 kts, If I get slower (because the nose is up) then my temps increase. If I lower the nose for the temps, then my climb decreases to less than 200 fpm. It’s my temperatures that are keeping me from pushing up the throttle and pointing the nose up a bit more.
  • I would currently never get 3,250 rpm at gross. Only with me in it and below 1,000 lbs. But maybe that’s because the temps have kept me from even trying. At gross I often have to step climb. Climb; temps go up; level out; temps go down; climb a bit; temps go up; level out; temps go down, etc, etc.
  • When I had the ground adjustable prop I had to set it to the finest pitch (0 - zero) to even get my rpms up to 3,000. Most of the time I could not get the rpms past 2,950, and my climbs and gross weight performance were just as they are now: awful. So I never got any satisfactory numbers during tests. They were anemic and within a very small range. What has changed since I changed to the cast iron cylinders is that I still have scary small climb numbers, but now with the added issue of hot cylinders. The only thing different about the ground adjustable prop was that even at the finest pitch setting I was getting 105-107 kts in cruise.
  • At gross, when I take off, to clear 60’ trees that are a fair distance beyond the end of the 2,700’ runway I have the airspeed in the 60+ kt range, and I often see them dipping into the 50’s. My fpm climb is in that 150 fpm range. I can’t pull the nose up any higher and I can’t flatten my trajectory. I just have to hold the stick, hold my breath, and pray there isn’t a hiccup in the engine. If I’m that draggy then I would think those issues would be patently obvious to even a casual observer.
  • It feels like I need 2" of extra prop, and an extra 200-300 rpm to swing it.
  • Sonex acknowledged that at one time some incorrect cams had been shipped, but they said my engine kit was some 200 kits beyond that known problem, and their shipping information shows I had the right one.
  • When I had the Nickasil cylinders I had NO problems with heat. None at all.
Posted: Mon Jun 06, 2016 9:55 pm
by Fastcapy
I will get yelled at (again) by admins if I go into it, so all I will say is good luck and that I and others have felt/feel your pain.
Posted: Mon Jun 06, 2016 10:38 pm
by n502pd
Have you degree wheel checked the cam for actual lift and duration? you will need dial gauge for lift measurments. Did you do the rebuild yourself? When I set the cam timing I took a picture of it as proof!! What you describe really sounds like a retarded cam, or a mis-ground one, one way or the other.
Have you compaired the thrust from your plane to another identically equiped plane, using a scale tied to tailwheel and a tree? this way you can change things and test for more or less thrust without flying, and wasting your nerves. Feel free to PM me if you need more info. :slight_smile:
Posted: Mon Jun 06, 2016 11:42 pm
Your speeds and climb performance seem to indicate you are getting about 80% as much power as I am. Have you checked recently that the throttle is free to open completely? Is it possible for there to be some slop or stretch in the system so that when the engine is running the throttle hits a different stop before opening completely? Ever experimented with a less-restrictive air filter?
What compression ratio and combination of shims did you use when rebuilding the engine?
I’m really hoping you figure this out soon.
Posted: Mon Jun 06, 2016 11:52 pm
by radfordc
mike.smith wrote:- Ever since then I usually average about 4.5 gph. So to me, 4.09 gph is too lean and may be part of my heat problems. It can’t hurt to check so I’ll richen the mixture a bit and do some tests.
The very least fuel burn I ever saw was over 4.75 gal/hr in cruise flight at altitude with the mixture leaned severely. Making power I always saw over 5 gal/hr.
Posted: Tue Jun 07, 2016 12:08 am
by nwawingman
I agree with your numbers Charlie. I personally run my AeroVee just lean enough to run smooth. Lean anymore than that and I see my temps climb. I find that the cylinders heads are much cooler that way and I average 5 gal/hr.
Posted: Tue Jun 07, 2016 12:21 am
by wlarson861
You may have alluded to one of the problems. When I got rid of the Nikasil cylinders I think it took about 30 to 40 hours for the temps to get back to “low” They would still hit 400 to 410 on climb even solo on really hot days. When I was normally aspirated 390 was a good day climb temp at 80 OAT. Solo climbs were still around 600 fpm though with a Prince prop. Another thing I did was look at the bottom opening and realize the engine mount crosses the firewall right above the exit, I added about 1.25 inches to the opening to compensate for this and saw a slight reduction in temps. I think I suffered from too much anxiety over some things that breaking in the engine fully solved. Trying to cool a new(er) engine is just impossible until it is ready. As far as the climb performance I bit the bullet and went turbo. All My problems with cooling and climb went away and I rarely see climb temps above 380 now. It’s a $4000 fix but to me was worth it, the Jab was a lot more than I was willing to go at the time.
Posted: Tue Jun 07, 2016 11:36 am
by SonexN76ET
Mike,
Here are a few other items for you to check:
  1. Make sure your flaps are not too far retracted. If they are too far in the up position the aircraft will mush through the sky and not climb well because the wing is developing insufficient lift. Both climb and airspeed will be poor. On the other hard if they are set too low they will increase lift but also cause additional drag.
  2. Make sure you have an accurate slip/skid indicator ball. The Sonex demands that the ball be perfectly centered to get maximum climb and cruise performance.
  3. When you had the issue with your valves burning with your first engine build, a more likely cause than running too lean was that your valves were not fully closing. The manual states setting the valves to .006 in one are and to “between .006 and .008” in another. If you can just barely squeeze in the .006 feeler gauge, it could be that you have less than .006 and your hotter valves will not be closing fully and will allow carbon and lead deposits to form and then start to burn.
  4. I would also go to an airport with a long runway (6000 plus feet) and try different takeoff techniques. With my Sonex, I have to accelerate in a flat attitude after liftoff to at least 80 mph before I can start comfortably climbing. Anything slower than this and my climb rate is poor.
  5. Check your wheel pants to ensure that when in flight they are not oriented where the wheel wells are pointing into the slipstream even a tiny bit.
  6. Perhaps smooth fairings for your gear leg intersection would help too.
I look forward to hearing your solution. Please be safe out there with your test flights.
Jake
Posted: Tue Jun 07, 2016 1:08 pm
by nwawingman
Excellent advice Jake! I especially agree with #4. There is a lot to be said for how we fly and getting the most performance out of our aircraft. I raise the tail around 40mph and rotate at 55 mph. Level out to build speed before I start my climb out about 80 like you referred too. It always seems to help my climb rate. I have watch others try to climb off in a three point attitude and it looks that there climb rate suffers. At full gross I will add a notch of flaps.
Posted: Tue Jun 07, 2016 9:50 pm
gammaxy wrote:Your speeds and climb performance seem to indicate you are getting about 80% as much power as I am. Have you checked recently that the throttle is free to open completely? Is it possible for there to be some slop or stretch in the system so that when the engine is running the throttle hits a different stop before opening completely? Ever experimented with a less-restrictive air filter?
8:1 compression, running on AvGas. I cc’d the volume in the heads so I know I have a solid 8:1 ratio. I have the big K&N air filter. The throttle moves to full throttle.
Posted: Tue Jun 07, 2016 9:51 pm
Sonex says their factory planes average 4 to 4.5 gph, so my usual numbers seem to be in line with that.
Posted: Tue Jun 07, 2016 10:16 pm
wlarson861 wrote:You may have alluded to one of the problems. When I got rid of the Nikasil cylinders I think it took about 30 to 40 hours for the temps to get back to “low” They would still hit 400 to 410 on climb even solo on really hot days. When I was normally aspirated 390 was a good day climb temp at 80 OAT. Solo climbs were still around 600 fpm though with a Prince prop. Another thing I did was look at the bottom opening and realize the engine mount crosses the firewall right above the exit, I added about 1.25 inches to the opening to compensate for this and saw a slight reduction in temps. I think I suffered from too much anxiety over some things that breaking in the engine fully solved. Trying to cool a new(er) engine is just impossible until it is ready. As far as the climb performance I bit the bullet and went turbo. All My problems with cooling and climb went away and I rarely see climb temps above 380 now. It’s a $4000 fix but to me was worth it, the Jab was a lot more than I was willing to go at the time.
I actually have about 35 hours on the new cylinders, not the 20 I stated. The turbo is certainly a possibility. Of course I’ll need to find hangar space that costs less than $500/month, first! I know VW never published max CHTs for these engines, but I feel like 410 deg is not a good way to treat these aluminum heads. I know a VW is not a Lycoming or a Continental, but those are aluminum heads too, and to quote Mike Busch:
Both TCM and Lycoming specify CHT limits (460°F and 500°F, respectively) that should be considered emergency limits, not operational limits. Allowing your CHT to get anywhere close to those values for significant periods of time will most likely result in premature exhaust-valve problems and increased incidence of cylinder-head fatigue cracking. I do not like to see CHT above about 400°F, which is the temperature at which the aluminum alloy from which your cylinder head is made loses one-half its tensile strength. (The strength decreases rapidly as the temperature rises above 400°F.) For legacy aircraft, I recommend a maximum target CHT of about 380°F just to provide a little extra cushion, and consider any CHT above 400°F to be grounds for “doing something right now” to get it down.
and
… a common misconception that burned exhaust valves are caused by high EGTs. This is not correct. Burned exhaust valves are caused by valve-guide wear and valve-stem wear, and the best way to keep that from happening is (1) to keep CHTs down, and (2) to run a lean mixture to minimize build-up of combustion byproducts on the valve stem. The leaner you operate (while keeping CHTs at prudent levels), the happier your exhaust valves will be.
So I like to set 390 as my warning area, and 400 deg as my upper limit, while striving to keep the CHTs at 380 or less whenever possible. Call me a granny, but those are my feelings about it.
Posted: Tue Jun 07, 2016 11:45 pm
An 8:1 compression ratio engine like ours gets about 14.3 hp per gph fuel flow lean of peak (which I believe would be best case for us since most of us are unable to operate LOP). 4.5 gph corresponds to about 65hp (14.3*4.5). I often fly WOT for the entire flight and burn over 5 gph–especially if I’m flying low. Probably not difficult to go as high as almost 5.5 if you are a little too rich or flying at low density altitudes.
The 4-4.5 gph number is a reasonable average for typical local flights where due to takeoff and landing you spend a significant portion of time operating lower than 80hp.
Posted: Wed Jun 08, 2016 9:57 am
by radfordc
gammaxy wrote:I really wish I understood how Sonex gets 150mph at 8000 feet.
Check out Jeff Shultz’s chart showing performance numbers for his plane/engine: http://www.sonex604.com/percent_power.html
He shows a TAS of 151 mph at 8000 ft.
Also note that at low altitude turning 3200 rpm requires 5 gal/hr. This is in line with what I used to see.
Posted: Wed Jun 08, 2016 1:43 pm
That’s a nice chart and the numbers seem correct near sea level (maybe even slightly slow), but I don’t believe the values at higher altitudes are correct. He doesn’t appear to make the claim that the higher altitudes were measured, so I think there is a math problem.
When you fly higher, the air is thinner, so there is less drag, but there is also less power available. These effects tend to cancel each other out so you end up close to the same speed, but then you have to fly at a higher angle of attack in the thin air to generate lift so drag is greater and the airplane flies slower.
A lot of airplanes are RPM limited and/or mixture limited at low altitudes, so there can be an increase of speed as you climb, but I’ve never experienced that in my Sonex since I happily fly at WOT at any altitude.
Here’s some math:
The power required to overcome drag is: Power required = 1/2 * air density * velocity^3 * drag stuff
If I make the same assumption that drag area doesn’t change when we climb to altitude, then 1/2 * (drag stuff) can be treated as a constant, C, when comparing performance at different altitudes.
Here, I solve for C:
76HP = C * (air density @ SL) * (130 TAS @ SL)^3
C = 76HP / ( (air density @ SL) * 130^3)
Now, I use C at 8000 feet to solve for the expected velocity due to reduced drag and engine power when the air is 0.77 times as dense as sea level air:
76HP * 77% = C * (air density @ 8000) * V^3
76HP * 77% = 76HP * (air density @ 8000) / (air density @ SL) * (TAS @ 8000)^3 / 130^3
(TAS @ 8000)^3 = 76HP * 0.77 * 130^3 / (76HP * 77%)
(TAS @ 8000)^3 = 130^3
TAS @ 8000 = 130
Notice how the decrease in engine power cancels with the decrease of drag to leave the expected TAS at 8000 feet the same as sea level. Trouble is, the lift generated will be 77% as much at that speed due to the thin air, so the angle of attack will need to be higher (more drag) and the airplane will fly even slower.
Posted: Wed Jun 08, 2016 4:41 pm
by radfordc
You math wizards will have to have a discussion among yourselves.
I do know that I admire Jeff’s work and I put a lot of trust in the Sonex guys, too.
There are plenty of references about TAS and they all seem to say that TAS is faster as you go higher.
http://stoenworks.com/Tutorials/Underst … speed.html
https://www.vatsim.net/pilot-resource-c … -airspeeds
http://www.pprune.org/archive/index.php/t-518735.html
Posted: Wed Jun 08, 2016 6:44 pm
radfordc wrote:You math wizards will have to have a discussion among yourselves.
The difference between TAS and IAS does increase as you go higher. Jet engine develop more power at faster speeds and really do fly significantly faster at higher altitudes with less drag. Normally-aspirated engines don’t, and lose power at about the same rate as the decrease in drag. Mixture settings and propeller limits combine to make it possible to fly a little faster at moderate altitudes, but I don’t think people fly the Aerovee anywhere close to RPM redline.
I somewhat regularly end up as high as 12,000 feet and have never noticed 20mph extra at 8000 feet. Has anyone else? I’d be happy to learn that someone does see this effect, because then I have room to figure out how to fly/improve my airplane.
I don’t mean to hijack the thread unless this conversation is interesting to anyone. I’m pretty happy with the performance of my Aerovee and think Mike would be happier with his if we could figure out what the problem is.
Posted: Thu Jun 09, 2016 4:43 pm
Hi Chris,
Thanks for your interest in my power chart! Developing a useful reference is never easy, and there are a bunch of variables that come into play. For my chart I used a combination of theory, based on empirical data and generalized curves, and tweaked it using actual flight test data. Although I can’t say I tested every value in the chart, I have found it to be quite close for those that I have tested. I have dozens of flight test logs that I’ve pored over and I’ve found that the old adage of TAS increasing 2% per thousand ft density altitude holds pretty close.
I generated a similar chart for my current Sonex with Jabiru 3300 and regularly refer back to it. It’s dead-nuts on for TAS and fuel flow, and I’ve come to really enjoy having it available in the cockpit. My current chart can be found in my POH. Feel free to review it at your leisure.
http://www.sonex604.com/misc/N604CM_POH.doc
I encourage you to get out and run your own tests. There’s no substitute for actual results, and first-hand knowledge beats theory nearly every time!
Posted: Thu Jun 09, 2016 10:32 pm
by samiam
Chris, your post uses a lot of algebra, but basically comes to the conclusion:
x = x
Or, in this case:
IAS = TAS. But science tells us that this simply isn’t true.
Posted: Fri Jun 10, 2016 6:30 pm
samiam wrote:Chris, your post uses a lot of algebra, but basically comes to the conclusion:
x = x
Or, in this case:
If I said anything about IAS, it is a typo. The point of the math is that drag decreases (if you make assumptions about angle of attack being the same at both altitudes) at the same rate that power available decreases as you fly higher. Best case is for your true airspeed at altitude to equal the true airspeed at sea level (not exceed it by 20 mph without some sort of explanation).
I think the reason why my argument seems so obviously wrong to people is that in a typical airplane like a Cessna 172, you can’t do 100% power in cruise near sea level without exceeding the redline, so you artificially limit the power to ~75% until you can finally go full throttle at 8000 feet (which then is only ~75% power). Because of this, power stays constant until 8000 feet while drag decreases, so you definitely do get a speed gain.
My Aerovee Sonex does not exceed red-line near sea level, so I happily fly WOT at all altitudes and power decreases as I climb. This is very unusual compared to typical GA airplanes and means expectations carried from more typical aircraft don’t apply.
sonex1374 wrote:Thanks for your interest in my power chart! … Although I can’t say I tested every value in the chart, I have found it to be quite close for those that I have tested.
Thanks for making your POH and all your other data so available. I’ve benefited from it enormously. The first thing that is surprising about your chart is that it shows 3300rpm at all altitudes. At WOT in cruise, I don’t expect to be able to get the same RPM at all three altitudes (for the same reason that a Cessna 172 at WOT near sea level will exceed redline, but not at 8000 feet). I think what the chart is attempting to show is that IF you ended up at 8000 feet in cruise at 3300 rpm, you expect 150 mph, but it’s not necessarily intended to indicate that you WILL get 3300 rpm. If that’s the case, then this chart shouldn’t be taken as evidence that 20mph+ TAS increase is possible between SL and 8000 feet.
Maybe your propeller allowed you to spin way faster than 3300 rpm at sea level and you throttled the engine accordingly. If this is true, then the chart makes more sense to me, but I think the percent power numbers should be adjusted to reflect throttling the engine down low and I’m going to buy a new propeller :-D.
Posted: Sat Jun 11, 2016 6:24 pm
I saw the resurrected canopy seal thread. Is the canopy fit pics he posted typical on other Sonexes? Seems like that could be a boatload of drag. Hard to get a good feel from a picture though.
Posted: Sat Jun 11, 2016 6:50 pm
To get the full performance from the Aerovee you need good compression on all cylinders. If you don’t have 70/80 you are loosing what you are talking about.
Posted: Sat Jun 11, 2016 7:10 pm
Onex107 wrote:To get the full performance from the Aerovee you need good compression on all cylinders. If you don’t have 70/80 you are loosing what you are talking about.
Nearly 80/80 on all my cylinders. I’m really at a loss to figure this out. I don’t have a heavy plane, I’m NOT draggy, I fly with the ball centered, I’m turning descent RPMs, I have a climb prop, but my climb sucks.
Posted: Tue Jul 05, 2016 10:20 pm
With lots of input from many sources (thanks everyone!) and some tinkering and tweaking I have been making improvements. Here is where I am at now, with comments in no particular order:
I ran the suggested in-flight test of the secondary and primary ignitions, but I wasn’t noticing a difference in CHT’s as you would see if the secondary ignition was advanced. But when WOT, or close to it, if I turned off the secondary ignition I would get a 100 rpm rise. It does not show up during a ground run up, where I can only get up to about 2,700 rpm before the brakes start letting me inch forward. So I retarded the trigger cap a little bit, and during the next flight I noticed only about a 30 rpm increase with the secondary off. With the secondary turned off my temps did go up. So I’m going to retard it a little more and see what happens.
My oil has always run too COOL, so I have been experimenting with the block-off plates I use in the winter to make the oil cooler opening smaller. With 50% of the opening covered I still don’t get oil over 180-185 degrees on even a warm day, so I’m going to try covering up a little more, for two reasons. 1) the oil needs to get hot enough to boil off the water, and 2) I am planning to go to the top-mounted oil cooler and am planning to cover much of the oil cooler opening to limit drag and pressurization the inside of the cowl.
During the annual last week I of course reset all the valve gaps. I have also been experimenting with a larger cowl exit by making (2) hinge pieces that I have been mounting across part of the horizontal pins of the bottom cowl. Essentially they spread the cowl wider across the width of the cowl bottom to let more air out. I did it a little and did not seem to do much. I did it a lot and it did have an impact, though I need more flights to verify, and I’m going to wait until I have the top mounted oil cooler before I make any permanent changes to the lower cowl opening, but for the time being it seems like an enlarged exit is in order.
I haven’t had time to try my fixes one at a time, but between the larger cowl exit, making sure the valves were set, less drag at the oil cooler inlet and retarding the trigger cap, my Sunday flight went REALLY well. I loaded me and 50 lbs of extra weights, plus full fuel and a half gallon of smoke oil to get up to 1,012 lbs. Taking off with a 90 deg cross wind and both ignitions on, I was getting 2,950 rpm with 350-400 fpm climb, and all my temperatures were way into the green even at WOT with a touch of leaning. If I turned off the secondary ignition I would get about 3,050rpm on climb out.
During level flight at 3,050 rpm I was at 98-100 kts IAS, 104 kts TAS. My hottest cylinder is #1 and it was at 1270 EGT/340 CHT. That is WAY better than I have been getting. I was leaned out about 1 to 1-1/2". After 2.4 hours of flight time, including two take-offs and two landings, I burned 3.95 gph! I was running lean during cruise, but even so that seems rather low. But my perception when I have run rich is that the engine seems to bog down a bit. Maybe it’s just perception so more testing is in order.
So all in all things are much better after those few tweaks :slight_smile: If you are having issues with power and/or temperatures maybe some of these things will help. But remember that 80 hp can only do so much, so keep your expectations in line with reality.
Oh, and during my compression test (cold) I got 79/80, 80/80, 79/80, 80/80 :slight_smile:
Posted: Tue Jul 05, 2016 10:38 pm
Mike
Thanks for the update. I was wondering how it was going.
Good to hear things are going better and I look forward to hearing about your trip at Oshkosh!
It’s funny you mention a bit of bogging down when rich. I am now convinced I had a set screw that was not holding in my AeroInjector mixture adjustment and I was experiencing a similar feeling. Let’s compare notes over a beverage.
Posted: Tue Jul 05, 2016 11:16 pm
Mike,
Any reason you don’t go wide-open-throttle during level flight?
I’d guess that 100rpm rise when turning off the secondary would be good for an extra 2.5 hp (from the Aeroconversions dyno chart)
Posted: Wed Jul 06, 2016 12:12 am
gammaxy wrote:Mike,
Saving fuel. Traveling out to OSH I want to get 3 hour legs with a comfortable reserve. I don’t see much increase in speed between 85% and 100% throttle, so why burn up extra gas for an extra 2 knots? If I get the secondary set right then I should get that 2.5 horsepower at my 85% setting. The only time I really need WOT is in a climb (including take-off).
Posted: Wed Jul 06, 2016 8:45 am
Mike,
What speed were you climbing at? The rpm numbers during climb still seem a bit low but you are certainly moving in the right direction.
Posted: Wed Jul 06, 2016 6:31 pm
kmacht wrote:Mike,
2,950 rpm at 350 fpm at about 78 kts. But I did not do multiple tests and did not write everything down, so I need to do a few more to get a better base line.
Posted: Wed Jul 06, 2016 9:25 pm
I retarded my secondary ignition a little more and went for a flight today. Retarding the ignition got me to the point where I can leave the secondary turned on and I get the same rpms as if I turned it off (maybe 10 rpm difference, but that’s close enough). It was 90 deg F on the ground and 78 deg F OAT during flight. Temperatures were all well in the green, with my hot (#1) cylinder at 1250 EGT/338 CHT when I was running WOT. Oil was at 174 deg F.
On take-off I had to lean about 1/2" or the fuel system skipped a beat at WOT. During flight it was fine at WOT, but I can see several rpm drop when I go to full rich.
On take-off the numbers bounced a bit, but at first 60 kt/ 455 fpm / 3060 rpm, then 68 kt / 500 fpm / 3068 rpm.
During cruise, when I climbed I saw 86 kt / 400 fpm / 3074 rpm, or 74 kt / 480 fpm / 2985 rpm.
I was at about 965 lbs including full fuel. Considering I have only 80 hp to work with I’m fairly happy at the moment.
Posted: Tue Aug 02, 2016 5:08 pm
by Sonex1414
Mike
Have you tried taking off your air cleaner? When I went on K&N website and checked their formula it showed that the standard air cleaner that comes with the AeroVee is not large enough to produce enough air to create 80 hp. I modified my air cleaner. At WOT I am turning 3550 RPM and showing 150 mph. Just a thought .
Posted: Tue Aug 02, 2016 6:28 pm
Sonex1414 wrote:Mike
I have the over sized K&N filter. I had to make a blister on the bottom of the cowl to get it to fit. I’ve run the engine with the filter off and didn’t see any appreciable difference.
Posted: Tue Aug 02, 2016 6:37 pm
Going to and from OSH this year, and putting about 20 hours on the plane, I was at about 75% full throttle, at 3,160 rpm, leaned back, doing 103 kts indicated, 106 kts TAS, burning an average of 4.5 gph. With the enlarged cowl exit my temps were so far in the green it was scary :slight_smile: Even on a hot day, high humidity, climbing out at full throttle, my hot (#1) cylinder didn’t get over 350 F, and EGT never got over 1350. In cruise that CHT was normally in the 315-320 range, with EGTs around 1290. The #2 and #4 cylinders are regularly in the 280 F range, with 1220 EGTs. Opening up the exit air made a HUGE improvement in temps. Like nearly a 100 deg F difference in both EGT and CHT! I’ll quantify the area and post it when I get a chance.
Posted: Tue Aug 02, 2016 11:48 pm
Sonex1414 wrote:At WOT I am turning 3550 RPM and showing 150 mph. Just a thought .
That’s some serious RPMs compared to what I see with my Prince 54x46. Are you using the Sensenich 54x44? What rpm do you get on climbout? I’m considering experimenting with a different propeller.
mike.smith wrote:Going to and from OSH this year, and putting about 20 hours on the plane
Sounds like things are working good for you now. I’ll be interested to hear more about your results from enlarging the exit. So far, my exit seems sufficient unless its a hot day and I’m operating near gross weight, but I can always keep the temperatures within limits by reducing the climb angle.
Posted: Wed Aug 03, 2016 3:03 pm
by jwd3ca
I came to the same conclusion several years ago with my 3300/AeroCarb, and went with a K&N RU-0660. I’m now looking for an air cleaner for an AeroVee/AeroInjector and would assume that the one that Sonex sells is being used by dozens of AeroVees with no issues. I just have to wonder why Sonex, after all these years, continue to recommend and sell an air filter that was incapable of providing sufficient air for the engine it was sold to fit? That just seems implausible to me…
