Aeroinjector WOT too rich?
Posted: Sat Dec 12, 2020 11:02 pm
by buffmaintainer
Hey guys, been tuning up my new Jabiru 3300. Im running an Aeroinjector with no.3 needle. I got it running very nice from idle to 2300 RPM. Im running a Sensenich 54-64 prop. Past 2300 rpm it breaks up horrible and begins to spark knock. Ive been leaning for best power, which is about 4 turns and I can achieve 2700 rpm static. once in flight I need to further lean or else cylinder 4 and 6 start creeping up past 1,400 degrees. I have no problem leaning but it just runs like crap below 2200 rpm.
I tried turning the needle in, and i can run it up to 2700 rpm no issues with good EGT but it will not idle even with the idle screw all the way in. If I back it off half turn the idle is fine again but still rich at WOT. ive found the “sweet spot” but its just not where it needs to be. I tried a 2.5 needle and just made things worse. I’ve tried tuning with cowl off, on, full fuel, cold days, hot days. Engine is brand new and has no induction leaks and I confirmed with smoke check. If I lean the engine for best power on takeoff it goes great but like I said it’s super touchy and if I put it back to full rich in cruise or landing, once I give it full throttle it balks and the EGTS sky rocket after 2300 rpm. I pull the mixture to lean and it clears up.
What can I do?
Re: Aeroinjector WOT too rich?
Posted: Sun Dec 13, 2020 2:32 am
by sonex1566
Hi Mr Frustrated!
Are you trying to tune the motor including when the throttle slide is wide open? Don’t get caught out as it is a trap. Advance the throttle until it starts to run rough and then shut it down. If you take a look at the throttle slide you will see that it still has maybe 1/4" - 5/32" to go until full throttle. If you adjust the length of your throttle cable so that full throttle in the cockpit equals that much throttle slide opening. I think that you are trying to make it run smooth with the slide open past the sweet spot which is then stuffing up the tuning down low. I personally think that when they go to wide open throttle the lack of a venturi causes the fuel to not atomize properly.
If you do a search for what Jeff Schulz has written he explains it pretty well. I do like the system…now. But there were times I felt like kicking the blasted thing into the weeds.
Good luck, remember to take deep breath, count to 10 and then REALLY let fly with that cursing!
Posted: Sun Dec 13, 2020 7:16 am
by lpaaruule
Sounds like you need to set everything back to factory default position, and restart your tuning for WOT. Once WOT is running well, then you can start adjusting the idle screw.
Also, make sure your system can flow enough fuel. If you’re flow testing isn’t giving you a number in the mid to high teens, you should address that first. No amount of carb tweaking is going to help if the rest of the fuel system is not flowing well.
I don’t restrict my throttle range. You’re EGTs will be lower, but you’ll also lose power. My last flight I had a peak EGT of 1335F. It’s been more at times, but you can always reduce throttle/power if you need to. I’m usually at 800AGL before my EGTs peak anyway, but the extra 50rpm is significant.
Posted: Sun Dec 13, 2020 1:17 pm
by buffmaintainer
I did the fuel flow test and it exceeded the mimium rate needed. Wouldn’t it be running lean if the fuel flow was too little? Like I said it seems way too rich at WOT and leaning the mixture clears it up. Plugs also indicate rich.
I didn’t think of the throttle slide. I am using the push open style and can’t really go to the other style because the builder of the airplane integrated it into the riveted panel. Ill take picture of the slide open and closed and post it here. But I did go back to factory settings. Thats where i can get it halfway decent.
Posted: Sun Dec 13, 2020 2:01 pm
Have you tried a 2.5 needle? I’m not sure how many 3300’s are using it, but the profile would give you a leaner mixture at open throttle than the 3.0 needle (assuming mixture at idle is the same.)
Posted: Sun Dec 13, 2020 3:04 pm
by lpaaruule
I agree that it appears you are way too rich.
Are you sure the needle hasn’t been altered by the original builder?
I think I typically have to screw the idle screw in a little if I richen WOT. Your result makes me suspect the needle or the carb, assuming there aren’t other factors such as a fuel pump, incorrect needle orientation, etc…
Posted: Sun Dec 13, 2020 4:49 pm
I had a similar issue not long ago. (General Discussion: Normal for an Aeroinjector?) Group “tunnel vision” would have you believe the injector/carb is never rich at WOT and lean at idle.
I purchased a replacement needle to compare it to what I had. They were for all intents and purposes, identical. What I did discover about the needle, however, was when it was leaned in the slide enough to make the engine run good at WOT, there was no taper showing in the orifice with the slide closed at idle. Armed with that tid-bit of information, I extended the taper with a few file strokes. My engine has been running fat-dumb-and-happy ever since. (Except for that Burp-thing).
The only explanation I have is an oversized orifice, which would require the needle to be set deeper than normal to facilitate WOT, thus starving the engine at idle.
Posted: Sun Dec 13, 2020 5:24 pm
by tx_swordguy
When you pulled the screw/ needle slide was there a lot of slop between the needle holder and the set screw? I had around 20 thous in mine and had to jerry rig a washer with a piece of aluminum. That really made it much easier to tune it by taking up the slack. It kept the needle from jumping around. Doesn’t take much to add or reduce a lot of fuel
Posted: Sun Dec 13, 2020 7:30 pm
sonex1566 wrote:If you take a look at the throttle slide you will see that it still has maybe 1/4" - 5/32" to go until full throttle. If you adjust the length of your throttle cable so that full throttle in the cockpit equals that much throttle slide opening. I think that you are trying to make it run smooth with the slide open past the sweet spot which is then stuffing up the tuning down low.
This is specifically mentioned in the AeroInjector manual. I was tweaking last week for best static RPM and went a touch too “open” on the slide and replicated this issue.
Posted: Sun Dec 13, 2020 9:23 pm
by lpaaruule
Engine “balking” or “over carburation” at full throttle? Yes it’s possible, but the carburetor is sized for the Jabiru 3300.
My understanding is that over carburation occurs when an engine isn’t pulling enough airflow to deliver the fuel adequately. This is mostly due to the Venturi effect in standard carbuators, but I guess that manifold pressure and air velocity could play a part in the AeroInjector.
If you’re only getting 2700 RPM at WOT, then it may be true that you’re over carburated, but it seems like that would mean the propeller was oversized, or there is an induction restriction, that is the root problem of the lower RPM, and thus airflow. In that case, limiting the throttle is patching the problem.
Perhaps I’m just lucky, but my 3300 can spin 2900+RPM static; on hot days 2950 RPM. On climb out approx 2850 RPM. She likes to breath, even which additional ducting for cold air.
Whatever the case, I hope you resolve the issue quickly
Posted: Mon Dec 14, 2020 12:23 pm
I agree with Richard. I had the same problem with my last Waiex, a legacy airframe with a 3300. Turned out that, as mentioned in the Aeroinjector tuning manual, it is possible to have the throttle cable adjusted so as to allow the slide to open “too far”. Once I recognized the symptoms I corrected the adjustment and everything became right with the world.
I’m not saying that it might not be something else, but that was my exact experience with the exact same symptoms.
Posted: Mon Dec 14, 2020 11:59 pm
Someone mentioned a “fuel pump”. They are a no no on an Aeroinjector.
Posted: Wed Dec 30, 2020 4:13 pm
by buffmaintainer
Alright so today I got the 2.0 needle installed and the WOT is no longer rich. Ive got the temperatures under control. But im pretty sure I still have a RPM issue. I can get 2600 Static RPM on the Sensinich 54-64 and 2750 rpm if I turn the screw in further, but the EGT and CHT temps are way too high. What should my static tuning RPM be?
Posted: Wed Dec 30, 2020 4:55 pm
buffmaintainer wrote:What should my static tuning RPM be?
Discussion Here:
http://ereksonfamily.org/sonex/aerovee- … ets-80-hp/
Posted: Thu Dec 31, 2020 1:58 am
Brandon, confirm your aeroinjector is on a jab3300?
added:
Thanks yes paul i looked over thread, its already mentioned. jab3300.
Michael.
Posted: Thu Dec 31, 2020 1:13 pm
by lpaaruule
Skimming the tread, I didn’t see that this was already mentioned.
I know you said there are no induction leaks, but what about induction restriction? If the pressure is too low in your induction system, it may be “sucking” more fuel in than it should.
I saw that you ran without a cowl; have you tried a short run without the filter, or any other ducting connected to the Aeroinjector? Your engine seems to be “choking” on something.
You already said your prop was the correct size, but you may want to double check it.
Posted: Thu Dec 31, 2020 9:49 pm
by tx_swordguy
Two things, make sure the airfilter is big enough and clean enough to allow it to breath. Second if you truly are thinking you you have wide open cured and your temps under control go fly and see what it does on take off and in cruise. Ground running is really hard on jabs especially if fully cowled. I am not surprised your cht are high on the ground.
Posted: Mon Jan 04, 2021 8:21 pm
by buffmaintainer
The filter that aeroconversions recommends was modified by old owner, the filter was wayyyy too beefy and was choking. I ordered the filter that sonex recommends from their site, but for now i’m running with no filter. My static RPM is now 2800 rpm. It’s running great but unfortunately I can’t get cylinder 1 and 2 EGT below 1300. I tried 2, 2.5, and 3 needle, with no.3 being acceptable. The 2.5 seemed to have worked okay with somewhat good EGT but idle had to be leaned almost to shut off. Right now it’s running great.. just can’t get the EGTs to come down on 1 and 2. I hate running this thing on the ground but it tried to kill me once already and I want it close.
Posted: Mon Jan 04, 2021 9:22 pm
by lakespookie
I would not worry to much on EGT’s if CHT’s are ok they can very alot based on sensor placement among other things and as long as CHTs are in control the EGT is more of a reference item than anything else for leaning CHT are what kills aircooled engines more so than EGT’s the reason we really need the EGTs is for leaning.
Posted: Tue Jan 05, 2021 12:17 pm
by buffmaintainer
I talked to one of the Rebuilders of the 3300 and he pretty much confirmed what you guys said. He said that 1200 to 1350 is normal EGT and that sensor placement can be a big factor why they are reading higher. Cylinder 1 and 2 are very sensitive to placement. I will still try and adjust for the best temperatures. He said that the 3300 doesn’t begin hurting itself until around 1500 degrees, and he usually looks for 1200-1350 on EGT. I pulled plugs and they show perfect combustion. Slightly dark with tan ceramic. He said keep eye on CHT and as long as they are under control it should be fine. Ill report back with aby more findings. Just an FYI, I found the airfilter that was installed looked brand new on outside, but the fuel would soak the elements and they absorbed carbon, soot, and oil which caused filter to restrict. Honestly this got me pretty good.
Posted: Tue Jan 05, 2021 10:01 pm
by lpaaruule
Glad to hear you got it figured out.
If my EGT climbs to 1400F on climb out, I just back off the throttle about 50RPM; the temp comes right down.
Posted: Wed Jan 06, 2021 1:32 pm
buffmaintainer wrote:I talked to one of the Rebuilders of the 3300 and he pretty much confirmed what you guys said. He said that 1200 to 1350 is normal EGT and that sensor placement can be a big factor why they are reading higher. Cylinder 1 and 2 are very sensitive to placement.
Regarding EGT sensor placement…I once ran an experiment where on cylinder #2 I installed 2 sensors an inch apart (3" & 4" down from the flange) on the header pipe. There were rumors floating around then, and apparently now, about how critical sensor placement was in regards to the measured EGTs. There were two runs done with the sensors reversed in the second run to account for the error in each individual sensor. The results of my tests showed that there was less than 10 degrees difference in the readings obtained from sensors installed an inch apart from each other. This is rather insignificant with absolute temps measuring well over a thousand degrees. Has anyone else run this experiment? It would be good to know that someone else has independently come up with the same findings before accepting them as valid, and perhaps, putting these rumors to rest.
Posted: Wed Jan 06, 2021 1:54 pm
by lpaaruule
I haven’t done that experiment, but the moderator on the official Jabiru forum said stated something very similar to your results. The big issue with placement is keeping it far enough away from the “flame front”; which is why they now recommend a further probe placement than they used to.
Below is what I’m referring to:
https://jabiru.net.au/service/technical … /#post-234
question:
I see from JSB 18-2 page 10, that the EGT sensor should be installed 120 mm from the face of the exhaust.
In my Storch HS the factory installed the single sensor approx 50-60 mm from the exhaust of left rear cylinder. How will this typically effect the reading? Higher or lower temperature? How many deggrees +/-?
Answer:
I think the 120mm minimum is mainly to ensure the reading is stable, to extend the life of the sensor and get it away from any standing flames coming out of the port.
I would definitely expect the reading to be higher, though probably not by much - a wild guess would be 0 to 10 degC higher.
Hi Guys,
I recently installed an AeroInjector on my Hummel 2400 engine and have been trying to get a good tune. It’s pretty busy at my airport so I have to get there early in the morning to get in a flight before there is too much traffic to fly a tight pattern. So, only two test flights so far.
I am encountering the problem mentioned in the manual as shown below. Back off the throttle just a bit, and smooth running again.
I don’t want to limit my manifold pressure by making this adjustment.
Question: What causes this problem?
When it happens, I see a drop in EGT, but I don’t know if it is due to misfires or extra fuel being dumped into the system.
I think this is easy to troubleshoot - what happens if you lean it? We never fly full rich.
It doesn’t happen on the ground. I happens about halfway down the runway, well after liftoff. To add to that, I got fooled by the throttle quadrant. I thought the pointer of my left hand would fit between the quadrant and the mixture control. It won’t. So, it is awkward to lean with the button lock cable.
All excuses aside, I haven’t tried that yet. I did advance the throttle wide open on downwind to ensure that the problem was repeatable. I’ll try leaning next flight. The weather is about to go down here for a few days.
I still have the question: What causes this problem?
It’s apparently common enough to deserve a special note in the manual.
I’ve never understood why it happens. We have never observed it. But it runs like crap if it is too rich. We typically lean before takeoff - not in a full power run, but we estimate where to put the mixture and just watch the EGT to make sure it stabilizes below redline on climbout.
I couldn’t stand the sad look on N151NX’s face, so I spent the morning freshening up the polish job. The weather is down until Monday. Here is the rest of the story of my tuning attempt.
The initial tune was done at home without the cowl, airbox and air filter. There was only about two gallons of fuel in the tank. The #3 needle was installed. The hottest EGT peaked in the mid 1300s at WOT. The engine took fuel well from idle to WOT and Idled well.
The first test flight was with filter, airbox, and cowl on. 12 Gal of fuel in the tank. The engine ran well. While climbing out the engine began to mis badly as noted by me and observers on the ground. I instinctively reduced power and the engine smoothed out. When the engine began to mis I glanced down at the EGTs and they were down in the mid 1100s. I assume that the extra fuel on board, etc., caused the engine to run much richer than it had at home. The EGTs remained low while I completed the pattern. I assumed the engine missing was a result of a too rich setting.
I had previously drilled the hangar floor to bolt the Onex down, just like I had done at home. So, off with the wheel pants and into the hold downs. We leaned the AeroInjector one full turn. The engine still took fuel well and idled well. I decided to fly another lap around the pattern.
This time the rough running occurred earlier in the climb than it did the first time. I backed off the throttle and the engine smoothed out. This time with the EGTs in the mid 1200s.
I probably backed off the throttle more than necessary. I just backed off until it ran smooth again. In any event, I held 3000 RPM and still had comfortable climb.
Next flight I will lean and see if the problem goes away. But I suspect that that note in the AeroInjector manual was written especially for me :slight_smile:
It will run much leaner at 2 gallons than any reasonable amount of fuel. Head pressure is part of the equation. I’d tune it with more fuel.
Yea, I didn’t think it would change that much. I wanted the EGTs to stay below 1400 at WOT with low fuel.
The more things change the more they stay the same.
It’s interesting to watch the whole video and see the similarities and differences between the Super Posa and the AeroInjector.
I think I’ll back up and follow the instructions more carefully (100 Deg. rich of peak) and see how things go.
